Bank 1 sensor 1
Results 1 to 10 of 10
Cadillac Catera and Cimarron Forum Discussion, Bank 1 sensor 1 in Past Cadillac Vehicle Discussion; I got code 0135 and 0115 o2 sensor bank. 1 sensor 1 and coolant temp sensor circuit . Changed temp ...
    98Geldog is offline Cadillac Owners Fanatic
    Automobile(s): 1998 eldorado, 2000 Catera
    Dec 2010
    Chicago
    247
    Bank 1 sensor 1
    I got code 0135 and 0115 o2 sensor bank. 1 sensor 1 and coolant temp sensor circuit . Changed temp sensor code still there. My question is bank 1 sensor 1 is the right side before the cat. Is this a upstream or downstream sensor? I'm going to by it from rockauto and need to know exactly what I'm getting. Thanks for any info.
    Dec 2010
    Chicago
    247
    Re: Bank 1 sensor 1
    Ok I don't get it. I replaced both of these sensors, erased the codes and they still come back like right away. They were the correct parts because they are exact from the ones removed. All connections look good from what I can see. What could be the issue? I have a 2000 body but a 1999 engine. Does the computer look for something different from the two years or what. Please help
    Oh by the way the car runs perfect. But this service engine light is very annoying
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Re: Bank 1 sensor 1
    how do u erase the codes
    Dec 2010
    Chicago
    247
    ODB2 scanner take it to autozone they'll do it for free
    olddavid is offline Cadillac Owners Member
    Automobile(s): 93 Eldorado(sold)99 SLS(sold) 98Catera
    Mar 2007
    Depoe Bay, Oregon
    58
    Re: Bank 1 sensor 1
    I went through a similar stretch sometime back. I finally managed to clear my light by cleaning the contacts on the MAF plug. How much for the sensors in Chicagoland?
    Dec 2010
    Chicago
    247
    Expensive about $260. Me personally I went to the none yard and the two cat that were out there I pulled the MAF but not luck. But I will try cleaning the connector.
    nethic is offline Cadillac Owners Member
    Automobile(s): 1998 Catera
    Nov 2012
    Sudbury
    43
    Re: Bank 1 sensor 1
    If doing regular maintenance of the exhaust system, what would you change first, downstream o2 sensors or upstream o2 sensors (front ones first or back ones first) ? and how does it matter?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    O2 sensors are part of the emissions system, not the exhaust system. "Regular maintenance" does not apply to O2 sensors, they either work, or they don't. If there's a problem with an O2 sensor, a code will set,and the CEL will illuminate.
    Dec 2010
    Chicago
    247
    O2 sensor code went away. Coolant temp sensor reading 280 should be around 220. Small leak in the radiator, someone put JB weld on it. 300+ bucks just for the radiator!
    Nov 2012
    Sudbury
    43
    Re: Bank 1 sensor 1
    Quote Originally Posted by 98Geldog View Post
    I think I seen a couple on ebay for less then that. let me see if I can find them and post them here for you
  13. Remove Advertisements
