Alternator Question
Results 1 to 8 of 8
Cadillac Catera and Cimarron Forum Discussion, Alternator Question in Past Cadillac Vehicle Discussion; I have a 99 Catera and the voltage guage reads just below the half way mark. When I out the ...
    w98seeng is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville
    Mar 2011
    54
    110
    Alternator Question
    I have a 99 Catera and the voltage guage reads just below the half way mark. When I out the rear defroster on the needle drops to almost the red zone. I have been havinh problems with the battery dyeing after driving the car on short trips, so I presume the alternator is going.
    I will check the free stuff first, but I am sure I need an alternator. I know there are different brands of alternators available but would parts from one fit another?
    I want to get a rebuild kit but I do not know the brand already in the car (original?). Also, is there a diode in this alternator or is that old technology? I am asking because a rebuilt kit I saw comes with bearings and a voltage regulator/brushes. I used to replace the diode when rebuilding alternators, but that was years ago.
    Thanks for the info,
    Ian
    marko69 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera Sport, 1990 Porsche 944 S2 cab
    Jun 2011
    Tampa
    109
    Re: Alternator Question
    I had problems of the battery dying intermittantly and right after driving it sometimes. Long story short, it was a bad positive battery cable. See if there are any brown sections on the cable and if the cable is frayed at the battery connector. Worth a look.
    98Geldog is offline Cadillac Owners Fanatic
    Automobile(s): 1998 eldorado, 2000 Catera
    Dec 2010
    Chicago
    247
    Same here bad positive terminal. Doesn't look like it made very good
    olddavid is offline Cadillac Owners Member
    Automobile(s): 93 Eldorado(sold)99 SLS(sold) 98Catera
    Mar 2007
    Depoe Bay, Oregon
    58
    You are obviously in my age cohort. I also remember the isolation diode as the first check after the battery when having charging problems. I doubt if modern autos are equipped with said diode, but I've always been baffled by electricity. I would recommend trying the Omega Owners site, but I keep getting banned from using it without any apparent reason. In Europe, these cars are more plentiful and those Englishmen are very resourceful about keeping them on the road and posting easy pictures to allow follow along repair. Knock on wood, but I have only had the intermittent door lock problem in the electricity department. The alternator is probably fun to change, yes?
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    my 97 would do the same, as long as I didnt turn everything on gauge would stay at 12V, as soon as I turn lights, heater, defoster on it would drop to almost 10V, so I replace the ground terminal and clean the pos-terminal and still the same so i bought a 140amp alternator on e-bay and install it, now the gauge only drops to 11.5V when everything is on, when everything is off 12.5, FIX ;-)
    Mar 2011
    54
    110
    I thought I would update this post. My Catera sat for most of the summer because I needed my van for work. Today I added a cable from the alternator
    to the battery and the electrical problem went away.
    I ran the car with the climate control on, the rear defroster on and the headlights on. The volt meter needle moved a small bit, which is normal, nothing like it did before.
    Ian
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Thanks for the update. My gauge reads barely 12 Volts most of the time. I'll check out the Positive cable soon. It would go a long way to explain some of the electrical gremlins who live in my Catera.
    Mar 2011
    54
    110
    I checked the output at the alternator (at idle) and I was getting 13.7 volts. At the battery, I was getting 12.7, that's a big difference.
    I took an old jumper cable and used one cable from it and put on a couple of crimp-on terminals and added it to the alternator.
    Ian
  11. Remove Advertisements
