P0411
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, P0411 in Past Cadillac Vehicle Discussion; Hello i have a 2001 Cadillac Catera 3.0 been trying to fix this for awhile here is what i have ...
    darksky47 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    46
    UnhappyP0411
    Hello i have a 2001 Cadillac Catera 3.0 been trying to fix this for awhile here is what i have done i have replaced the Air By-Pass Valve,Air Check Valve,Mass Air Flow Sensor,done a smoke test on the vaccum lines checked if the air pump was running and blowing air because i took off the line at the pump to make sure it was working there was alot of forced air comming from teh pump.Someone said it could be bad Oxygen Sensors if it could be that how many of them are there on this car. i have a code reader INNOVA 3100E with Freeze Frame here is the Data. i posted the pictures i hopes it helps.thanks everyone.
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Re: P0411
    I just had a P0411 last month that I got rid of by putting a can of STP fuel treatment in. I've had the car a long time, and I vaguely remember doing this a couple times before as well.
    There are four O2 sensors, two after the exhaust manifold and two after the Cat converter. Usually, the O2 sensors give you their own codes.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Fuel system cleaner will have absolutely no effect on a P0411 code, or the O2 sensors, or any component of the A.I.R. System.
