Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: dropping rpm when brake
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    had this problem over a year now ((
    time to time when i brake and stop my rpm dropping to 200 or so, usually happened when im preforming stop and hold my brakes longer then usually, like if u coming to red light, 200 rpm remains for like 1 second or 2 and then rmp raise to normal 500
    HELP
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Re: dropping rpm when brake
    Any Idea?????
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    Come on?, someone out there must have had this problem and fix it, I have it too, but have no idea ether, any suggestions?
    Thank You
  5. #4
    jupiter57 is offline Cadillac Owners Member
    Automobile(s): '97 DeVille, '98 DeVille, '97 Catera
    Feb 2005
    Lancaster, Kentucky
    Not on a Catera, but I had the same thing happen years ago.
    It was a vacuum leak, related to the brake booster, can't remember if it was the check valve, hose, or booster.
    If I remember correctly, somehow, when you applied brake, the vacuum would go to "uncontrollably open"(?)
    Think I had to replace the booster due to a vacuum leak.
    Regardless, it sounds like a Vacuum leak to me, and the reason it appears while braking leads me to advise you to start at the brake Booster.
    Might try plugging the Vac. line to your brake booster first, then isolate each seperate vacuum line until you find the culprit.
  6. #5
    May 2012
    119
    ok what is a brake booster? and where is it located?
  7. #6
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    It's the large, round component between the master cylinder and firewall. Inside, is a large diaphragm, that uses engine vacuum to provide power brake assist.
  8. #7
    May 2012
    119
    OK, got it, so how does that, have to do with engine RPM dropping up and down sometimes, I can,t see that its even connected to the engine, if there was a leak in the vacuum there, then it would effect the braking system and not the RPM right?
  9. #8
    May 2012
    119
    opps
  10. #9
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
  11. #10
    May 2012
    119
    opps
  12. #11
    98Geldog is offline Cadillac Owners Fanatic
    Automobile(s): 1998 eldorado, 2000 Catera
    Dec 2010
    Chicago
    247
    Maybe IAC or TPS. As far as I know would cause idle problems.
  13. #12
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    in my case it started to do way more now, approx. every fifth stop or so....
    According to my research it related to air lost due to broke mane rubber seal in booster, i personally swap twice throttler body in pass year (got used from junk ward) they both worked the same, (guys IAC and TPS its one unit for 2000 sport, call "Throttler body" its $400 peace). that's not the problem!!!!. Brake booster $100. i would personally replaced next day, but i have All Data when i looked on procedures... i change my mind to do it, it's just to mush to do
    so any idea?
    Thanks
  14. #13
    Dec 2010
    Chicago
    247
    In my 2000 the IAC is mounted to the TB at the rear by the firewall it's got a couple vaccum lines connected to it. I have a similar issue, the car idles high at start cold or hot at around 250-300 and takes at least 1 minute to idle down and even then it stays above 1000 until I take off but while driving it fine. this also causes a hard shift. On a kinda warm day I will try to clean the IAC and replace all the vacuum lines.
  15. #14
    May 2012
    119
    nevermind
  16. #15
    Sep 2010
    East Boston MA.
    29
    26,323
    .....You COULD put in a little effort, and find the meanings yourself. There's a sticky right here on these forums:
    http://www.cadillacforums.com/forums...-acronyms.html
    Or GOOGLE IT.
    Or at very least, just ask nicely.
    The members here are not getting paid, and are not required to walk you through everything.
  • You may not post replies
