dropping rpm when brake - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Cadillac Catera and Cimarron Forum Discussion, dropping rpm when brake in Past Cadillac Vehicle Discussion; ...
  1. #16
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    Re: dropping rpm when brake
  2. #17
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    You came to these forums asking for help, which the members here have been providing you. If you don't understand something, fine, ask for an explanation, and you shall receive. .....But:
    Quote Originally Posted by gvjv3
    IAC??? TPS??????
    come on guys, what you think we spend are life studying Mech abbreviations
    ^^That^^ post has a bit too much of a snappy attitude to it. How are we to know that you don't know the meanings of the acronyms, AND that you're unwilling to invest a VERY small amount of effort on your part, to simply look up their definitions? We can't read your mind. Just don't expect to get more information than what you ask for, and if you have a question, word it a bit nicer.
    Lack basic thinking? Be nicer and help people out? Take a look through my nearly 10,000 posts, then tell me how many "bad comments" I've posted.
    If you still want help, use the link I posted to find the acronym definitions. They're all in there.
  3. #18
    May 2012
    119
    Thank You
  5. #19
    Sep 2010
    East Boston MA.
    29
    26,325
    TPS - ThrottlePosition Sensor
  6. #20
    May 2012
    119
    I think I Finally found it, at least in mine hope it's the same in yours, I found a Vacuum leak, and repair it, my Idle has stop jumping up and down, am going to drive it a few days to make sure that was it, then I tell you were it was.
  7. #21
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    well common leak on all cateras coming from secondary injection air pump it self, that located under driver side front bumper, if u start you car and its sounds like some one turn on vacuum cleaner out side, thats your pump got unsealed, its easy fix, new pump cost like $400, fix is like $4!
    To fix it u have to take down horn that next to the pump, then pump it self. u will see how rivits (that factory used) snap off. so i used long thin bolts (approx 2in long) with small nuts, its like 6 of them there. i did it like 2 years ago!
  8. #22
    May 2012
    119
    OK I no longer have my idle jumping, I found the problem by accident, I put my hand under the [COLOR="#FF0000"]Idle Control Valve 0280140567
    and my finger happen to cover a crack which was a vacuum leak, I repace it with one I got on e-bay $40.00 and my idle dosn.t jump anymore, check yours out.vacum.jpg
  9. #23
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Cool. But I don't have that valve.... My intake manifold looks different.
    Smacas throttle position sensor. I don't have it. If I'm not mistaken its all togather in my throttle body.
  10. #24
    May 2012
    119
    DO, DO"S, sorry about that, my part name is, Idle Air Control Value, see if you can find out what they did or move it in your year of car.
  11. Remove Advertisements
