2001 catera how to add to rear differential fluid and some stop leak?
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, 2001 catera how to add to rear differential fluid and some stop leak? in Past Cadillac Vehicle Discussion; 2001 catera how to add to rear differential fluid and some stop leak? where is the input plug at? easy ...
    liweih21 is offline Cadillac Owners Member
    Feb 2012
    45
    2001 catera how to add to rear differential fluid and some stop leak? where is the input plug at? easy or? please respond.
    jupiter57 is offline Cadillac Owners Member
    Automobile(s): '97 DeVille, '98 DeVille, '97 Catera
    Feb 2005
    Lancaster, Kentucky
    Re: 2001 catera how to add to rear differential fluid and some stop leak?
    I haven't had to check mine yet, so I can't comment on the complexity, but here is a diagram of the fill plug:
    It is in the middle left in the image,(looks like passenger side?) with a line pointing to it, and a number "1".
    Hope this helps.
    Feb 2012
    45
    hi jupiter1, quick response.... is this under the car from the driver side looking ?
    Feb 2005
    Lancaster, Kentucky
    Quote Originally Posted by liweih21 View Post
    Not sure, but I believe this view is from the passenger side.
    Jaeger63 is offline Cadillac Owners Member
    Automobile(s): none
    Sep 2012
    Gatineau, Quebec
    23
    Don't use stop leak. If it's leaking it probably needs a new seal.
    I haven't done it on a Catera but every other diff is essentially the same. You take out the fill plug and add the specified gear oil until it starts to run out the hole. Keep the car level while filling. Usually you can just squeeze the bottle to put the oil in, but sometimes you need a pump - depending on ease of access to the fill hole.
  8. Remove Advertisements
