Passenger side heat not working?
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, Passenger side heat not working? in Past Cadillac Vehicle Discussion; So my passenger side heat doesn't work, it blows cold air while the drivers said blows hot air like it's ...
    BossLady's Avatar
    BossLady is offline Cadillac Owners Member
    Automobile(s): 2004 CTS 3.2L 5 spd Manual-Black Beauty
    Sep 2009
    Washington STATE
    30
    78
    So my passenger side heat doesn't work, it blows cold air while the drivers said blows hot air like it's supposed to. Any idea what could be wrong? Something possibly disconnected, or blocked? I think the K 134 relay needs to be replaced because the radio, trunk, fuel door will randomly go out sometimes but I'm not sure if that would have anything to do with the heat, Im assuming not. Does anyone know where I can find that relay besides off a junk car?
    Thanks!
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: Passenger side heat not working?
    Welcome to my world. That was the last straw for me to get rid of the car. Actuator isn't working.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    u can fix actuator, by taking in a part and pushing shaft in to the motor that over time pushed out. save $130
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    as far as the K134, if you can get it out, under the dash, drivers side close to the door, gray box that clips to side, raise it up and pull it out, disconnect the wire, than open it up, pull out the relay board, look at the solder contacts on the back side and find the ones that are crack or loose, resolder the ones that need it, and put it back together and when you put it back, I advise you dont clip it back where it was but just let it hang with the wires connected to it, it's my opinion that closing the door many times cause the vibration that causes the solding points to crack
    May 2012
    119
    are you referring to this shaft?Attachment 100444
    May 2012
    119
    thank you
  9. Remove Advertisements
