2000 catear ground wires
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, 2000 catear ground wires in Past Cadillac Vehicle Discussion; hello! Does anyone out there know the location of the ground wires in a 2000 catera? I would greatly appriciate ...
    roadsidesaint is offline Cadillac Owners Member
    Automobile(s): 2000 catera
    Sep 2012
    6
    hello!
    Does anyone out there know the location of the ground wires in a 2000 catera? I would greatly appriciate any advice, previous exp, or even opinions, I have an issue with battery drain and want to make sure i have good ground connections.
    Thanks!
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Re: 2000 catear ground wires
    Just trace the wires from the negative battery cable to where it is attached to the engine block. I can follow mine until it disappears under the front of the engine and I guess you have to get under the car to see where it goes.
    I doubt that a bad ground cable would cause battery drain. It may keep the car from charging fully or reduce the voltage in the car.
    How do you know you have battery drain? Are you sure your battery and alternator are good?
