Cooling leak
Results 1 to 9 of 9
Cadillac Catera and Cimarron Forum Discussion, Cooling leak in Past Cadillac Vehicle Discussion; Hello I have a 97 Catera, the other day I went to check my coolant, I started to open the ...
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    WinkCoollant leak HEATER CONTROL value
    Hello
    I have a 97 Catera, the other day I went to check my coolant, I started to open the reserve tank then forgot it was still hot and it started to come out so I closed it before any coolant got out, now I have a leak some were, stream rises from the pass. side rear bottom of the motor, car does not get hot but i lose coolant, also if I turn on the heat the leak stops,
    any ideas what I should be looking for?
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Re: Cooling leak
    Nothing you did can cause a leak. It may be that some coolant remains in the overflow tube and drops down on the hot engine causing steam. Double check that you are still losing coolant.
    If you are still losing coolant, the location you describe sounds like the heater control valve.
    BTW, you are lucky you didn't hurt yourself.
    May 2012
    119
    ok, just strange when I turn on the heater no leak and when I turn of the heater steam comes out, yes I lose coolant, lots when I have the heater off, very little to none when i have the heater on, would anyone know where this heater control value is location is? and what it looks like?
    Thank You
    Nov 2005
    674
    Re: Cooling leak
    The heater control valve is back toward the firewall on the passenger side. It has three hoses and a vacuum line coming out of it. The easiest way to find it is to locate a heater hose and follow the hose to the valve. These valves are a problem area in the Catera and would be my first choice for finding a leak in the area you describe.
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: Cooling leak
    Quote Originally Posted by investor74 View Post
    Heater control valve is a common problem!
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: Cooling leak
    A HBV replacement article with pictures from the Omega Owners Forum:
    http://www.omegaowners.com/forum/ind...?topic=90574.0
    Be sure to thank them.
    May 2012
    119
    OK I found the value, its cover in coolant, so am sure it's leaking, now the only thing is how to replace it? I had to bend my arm 3 different ways just to reach down and back behind the motor just to grab it with my hand and feel it was all wet with coolant, there's no way i can get any tool in my hand back there, so do i take the manifold off? or is there a special way?
    Thank You
    oh by the way this site is banded for use.
    jupiter57 is offline Cadillac Owners Member
    Automobile(s): '97 DeVille, '98 DeVille, '97 Catera
    Feb 2005
    Lancaster, Kentucky
    Re: Cooling leak
    Quote Originally Posted by gvjv3 View Post
    Thank You
    Better link:
    May 2012
    119
    bad site, will not me in, thanks for trying.
  12. Remove Advertisements
