1998 Catera won't upshift
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, 1998 Catera won't upshift in Past Cadillac Vehicle Discussion; It's only got 90,000 miles so I hope the transmission isn't toast. Thinking it may be an electronic problem or ...
    atikovi is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Professional Chassis Raised Roof Presidential Limousine
    May 2003
    Suburban Washington DC
    400
    It's only got 90,000 miles so I hope the transmission isn't toast. Thinking it may be an electronic problem or sensor. Do they have codes that can be scanned? No lights are on in the dash.
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    Re: 1998 Catera won't upshift
    need more detail, does it have a hard time going from 1st gear to 2nd when cold, does it shift ok when hot? most common problem is you need to change the trans fluid and filter, not so costly to see if that solve the problem
