code p172 and p175, before was p171 and p174
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, code p172 and p175, before was p171 and p174 in Past Cadillac Vehicle Discussion; Hi, I got a mystery here, 01 catera, probably got scammed buying it. Took to reputable shop several times, in ...
    liweih21 is offline Cadillac Owners Member
    Feb 2012
    45
    Took to reputable shop several times, in the beginning was p411, fixed that with new ecu/ecm, then p172 and p172 came up, become hard to start in morning or after idle for more than a day but runs smooth, changed MAF, now the car idles bad and has p172 and p175 (changed MAF again, same).
    Verified all connections and harness everything seemed alright.
    What else could be wrong? could it be actual engine components?
    olddavid is offline Cadillac Owners Member
    Automobile(s): 93 Eldorado(sold)99 SLS(sold) 98Catera
    Mar 2007
    Depoe Bay, Oregon
    58
    Re: code p172 and p175, before was p171 and p174
    I have the same, but with 100, 101 and 154. My attempt will involve first attempting to clean my MAF connectors and replacing my bank 2 no.1 O2 sensor. Then I will check all vacuum hoses I moved when replacing my cam cover gaskets. Any other suggestions? How are you progressing?
    Feb 2012
    45
    changed MAF three times, not the reason.
    the car apparently was attempted to fix before.
    the entire air system has been changed, the engine just struggles to breath air, only once warm up it runs great.
    even the main ecm has been changed, do not see any leaks.
    no one said anything and o2 so far.
    it has 61k now.
