Rough idle and check engine light...
Results 1 to 9 of 9
Cadillac Catera and Cimarron Forum Discussion, Rough idle and check engine light... in Past Cadillac Vehicle Discussion; Me and my brother just replaced the valve covers with Saab ones, and installed a new ac compressor. Starts up ...
    IvoryWhiteCatera's Avatar
    IvoryWhiteCatera is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Catera (SOLD)
    Apr 2011
    120
    Me and my brother just replaced the valve covers with Saab ones, and installed a new ac compressor. Starts up just fine, but today I started it and the idle was rough and the check engine light flashed for a few seconds and went solid. Don't have a scan tool. Idle is a little rough and acceleration a bit sluggish.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: Rough idle and check engine light...
    Check the spark plug wells. They might be full of oil. If the gromets weren't installed properly they could leak oil under crankcase pressure.
    Apr 2011
    120
    Quote Originally Posted by elvin315 View Post
    No, fixed that problem recently. Went to O'Reilly and had it scanned. Misfire on cylinder 6.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    there is wire going to throttle body. make sure uconnect it good ,
    also clean connectors
    Apr 2011
    120
    Quote Originally Posted by JohnJJO View Post
    It's good. Maybe it's the coil or wires...or spark plugs.
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    sounds like a bad coil to me.
    ihad similar issue about 2 yrs ago.
    Apr 2011
    120
    Quote Originally Posted by hgqguy View Post
    Cylinder 6 is the only one misfiring.
    olddavid is offline Cadillac Owners Member
    Automobile(s): 93 Eldorado(sold)99 SLS(sold) 98Catera
    Mar 2007
    Depoe Bay, Oregon
    58
    I just completed the same job on my car (70k) and I needed new wires and plugs to go with the cam seals to get the car completely right. Mine kept saying no. 3 was malfunctioning. I found the oil had saturated the wire to the point it would not clean with alcohol or any other solvent.
    Apr 2011
    120
    Quote Originally Posted by olddavid View Post
    Thanks. I'll try that.
  12. Remove Advertisements
