| Re: Need some help!!! 97 Caddy!!! Let's clarify. You jump started the car and it ran, right? But the battery won't hold a charge? I assume you ran the car for a while 15-20 min to charge the battery up. Can the battery start the car immediately after being charged? Then, I would disconnect the battery overnight and see if it still has a charge in the morning. If so, something is draining it. Otherwise, your battery is bad. Take it back to the store for an exchange.
On my 98, there is a procedure to program the sunroof in the owners manual. It involves turning and pushing in the dial at different positions. Try that. No idea on the radio other than things will stop working with a low battery. But the car wouldn't start with a low charge either. |
