Rear differential removal, need to remove cv shafts?
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, Rear differential removal, need to remove cv shafts? in Past Cadillac Vehicle Discussion; So my new rear diff came in today. I started unbolting the old one on the car. I believe i ...
    devin28 is offline Cadillac Owners Member
    Automobile(s): 2001 catera
    Feb 2012
    ypsilanti, mi
    33
    31
    So my new rear diff came in today. I started unbolting the old one on the car. I believe i have everything unbolted. Looks like the cv axles are the only thing holding the rear end in place. To remove the cv axles do i have to take the tires, brakes, etc off and pull them out that way? Or is there an easier method? Thanks again for the help.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Re: Rear differential removal, need to remove cv shafts?
    no u dont have to . there is 6 hex bolts that hold axle to control arm.
    Feb 2012
    ypsilanti, mi
    33
    31
    Alright. Got that part done. Now do i need to remove the rear diff cover to get access to the other side of the cv joints to pull that side off?
    Feb 2012
    ypsilanti, mi
    33
    31
    I am having some real trouble getting the cv joints removed from the carrier itself. please help.
    Feb 2012
    ypsilanti, mi
    33
    31
    so i got the rear end down and out, the pass. side cv joint removed. The driver side cv joint is giving me some trouble. cant seem to lodge it loose from the carrier.
  8. Remove Advertisements
