Results 1 to 13 of 13
Thread: Location; oil sending unit (light)
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    Question Location; oil sending unit (light)
    Attachment 97512Can anyone tell me where the oil LIGHT sending unit is location on a 1997 Catera is?? its the switch that controls the RED oil bucket w/spout light on the instrument panel NOT the oil pressure unit that controls the PSI gauge on the instrument panel
    Thank You
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Should be screwed into the side of the oil pan.
    May 2012
    119
    Re: Location; oil sending unit (light)
    No had the oil pan removed and clean, nothing there
  5. #4
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    are u sure u dont have that type of switch?
    its connected to oil pan facing to the front
  6. #5
    May 2012
    119
    Yes, that is the oil pressure unit, it works as the oil pressure gauge on the instrument cluster that shows what the psi is, 1997-1999 has 2 switches, one for the psi another for the oil light
  7. #6
    Sep 2010
    East Boston MA.
    29
    26,323
    Sorry, I thought you were referring to the oil LEVEL sensor (the one that triggers the orange oil level light). The oil PRESSURE switch (the one that triggers the red oil pressure light), is internal, located near the oil pump.
    The oil pressure sender (the sending unit for the oil pressure gauge), is located on the front of the block, near the crank pulley.
    Edit: Oh, yes, I was wrong. The level sensor requires a pan drop to replace, it is not threaded into the side of the pan.
  8. #7
    May 2012
    119
    ok, the light that comes on is red and looks like a oil bucket with a spout, please is you can explain more of : The oil PRESSURE switch (the one that triggers the red oil pressure light), is internal, located near the oil pump.: what do you mean "internal" ? where would the oil pump be?
    Thank You
  9. #8
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    look at 4 or 6
    dont worry about picture that lower, its ecm i attached by accident, dont know how to remove it
  10. #9
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    What needs to be done is an actual oil pressure check to determine if its internal problem or just the idiot pressure switch that could be out of calibration.
    Below are probable causes:
    Excessive main and rod bearing clearances (someone may have installed the wrong-sized bearings or standard-sized bearings on a reground crankshaft). Only 0.001-inch of extra clearance in the main bearings can reduce oil pressure up to 20 percent!
    Excessive camshaft bearing clearances (a bearing may have slipped out of place when the cam was installed).
    Excessive clearances inside the oil pump.
    Leaks between the oil pump and engine.
    Oil pump relief valve stuck open or installed backward.
    A loose or mispositioned oil pickup tube (too high in oil pan).
    A defective oil pressure sending unit or oil pressure gauge.
    Low oil level in the oil pan.
    Cracks or leaks in the oil galleries or gallery plugs.
    Cracked oil pump housing (improper installation).
    Oil viscosity too thin for hot weather.
  11. #10
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by JohnJJO
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=97625"/>
    look at 4 or 6
    Is that from your '00 FSM? '98-'99 cars use both a pressure SENDER (a variable resistor that reacts to pressure) for the gauge, and a pressure SWITCH (an on/off switch that activates at a preset pressure) for the light.
    The pressure SWITCH is behind the timing cover.
  12. #11
    May 2012
    119
    4 is the pressure unit that controls the psi gauge on the instrument panel, 6 is the low oil senor which controls the orange low oil light on the instrument panel , am looking for the switch/senor that controls the red oil light.
  13. #12
    May 2012
    119
    ok we are getting closer, I know the timing cover, black with 2 bolts, so I remover it, than were? down, left -right? can i see it after I remover the cover?
    Thank You
    for other answering, good oil pressure, oil full and clean, no noise, no leaking, just a idiot light senor too old and went bad,
  14. #13
    Sep 2010
    East Boston MA.
    29
    26,323
    Look down and to the left (your left, the cars right side) of the crank pulley.
  • You may not post replies
