Catalytic converter question
Results 1 to 11 of 11
Cadillac Catera and Cimarron Forum Discussion, Catalytic converter question in Past Cadillac Vehicle Discussion; I have 98 Catera that's in need of new cats. Are the Catalytic converters used on a 2001 Catera able ...
    98Catera_2010's Avatar
    98Catera_2010 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Cadillac Catera Sport
    Oct 2010
    Cookstown, Ontario Canada
    28
    242
    I have 98 Catera that's in need of new cats. Are the Catalytic converters used on a 2001 Catera able to be used in mine? I have opportunity to grab a set off a 2001.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Re: Catalytic converter question
    Same engines so I would guess same cats.
    Oct 2010
    28
    242
    I was thinking the same just hoping there exact fit.
    Quote Originally Posted by elvin315 View Post
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    36
    449
    Take a look ar your cats. see if the O2 sensors are located in same spots. I belive my 01 has mid bed o2 sensors. We ordered cats that were supposed to fit to find out that they did not.. i belive the older models may not have the O2 sensor in the convertors. I replaced mine with BRAND NEW aftermarkets for $240 including instalation.
    taf9664 is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Catera
    Mar 2013
    47
    5
    Hgqguy...would be great to know where you bought the converters from and a part number if possible. I am looking to buy an aftermarket set of converters also and I wanna make sure I get some that are gonna fit properly. I have an 01 Catera also. Did you notice a huge difference in performance and/or fuel economy before and after the converter replacement? I am getting around 10-12 mpg at this time. I did a temperature test with an infrared temperature gun and both of mine have failed. Please help!!!
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    What do u mean by saying that test is fail. What reading u got after temp test. After my temp. test I got on driver side 256F before and 265F after cat. On pass. side got 270F before cat. and 302F after.
    Mar 2013
    47
    5
    Read tons of post regarding temp before and after cats. If temp before cat is greater than temp after cat...then your cat could be clogged. Based on the temps you are giving I would say your cats are still good.
    Temperature before my cats was about 100 degrees hotter than after.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by JohnJJO
    how long were you driving before measuring the temps?
    Mar 2013
    47
    5
    I checked it at about 10 minutes and again at around 20.
    Sep 2010
    East Boston MA.
    29
    26,325
    Of running or driving?
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Drove about 30 min. Tested on running vehicle.
  14. Remove Advertisements
