knock sound
Results 1 to 7 of 7
Cadillac Catera and Cimarron Forum Discussion, knock sound in Past Cadillac Vehicle Discussion; Really bad knock sound, shakes motor, sounds like on pass side. does it only around 1g. wether getting on gas ...
    oilleak is offline Cadillac Owners Member
    Automobile(s): Catera
    Aug 2012
    15
    knock sound
    Really bad knock sound, shakes motor, sounds like on pass side. does it only around 1g. wether getting on gas or off. have a leaking oil cooler.
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: knock sound
    Main bearing going?
    Pee_beds is offline Cadillac Owners Member
    Automobile(s): 1998 Catera
    Aug 2012
    Calgary, Alberta
    36
    5
    Re: knock sound
    How is your oil pressure?
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Re: knock sound
    If you've been running with a leaking oil cooler it could be one or all of your engines bearings. Whatever you saved on the purchase you're gonna blow on a rebuild or engine swap. You may as well part it out.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Re: knock sound
    man u need to re-write your question! i dont know where u came from but first of all u need to make sure u write it right, that people can understand u and give u the right answer for the right question. Im from Ukraine live in the states for 4 years already, personalty think my posts people can understand with no problem! so now can u tell me exactly what the problem is ?
    whats mean " wether getting on gas or off" u mean "weather" ?
    whats mean your "1g"
    Come one lets help each other, to understand batter here on the forum, thats what that forum was mad for
    Thanks
    Aug 2012
    15
    Re: knock sound
    Oil pressure is around 70. If you are sitting in the yard and rev it up to 1,000 rpm it makes a bad knock sound. sounds kinda like you putting a card in a bycicle wheel. But if you rev up past 1,000 rpm it goes away. As soon as you get off the pedal it will make that sound around 1,000 again and sometimes while its idleing at 500 rpm.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Re: knock sound
    ask your friend to help u , let him seat and hold rpm until that noise come back, u look for that noise if it really coming from pass. side like u saind thats main bearing. i would say that could be valve stuck , lifter or timig belt 1 tooth got loose
  10. Remove Advertisements
