New catera owner really need help
Results 1 to 14 of 14
Cadillac Catera and Cimarron Forum Discussion, New catera owner really need help in Past Cadillac Vehicle Discussion; Just bought a 2000 catera very clean chrome wheels, sunroof, and a rear window shade. But oil and antifreeze are ...
    98Geldog is offline Cadillac Owners Fanatic
    Automobile(s): 1998 eldorado, 2000 Catera
    Dec 2010
    Chicago
    247
    Just bought a 2000 catera very clean chrome wheels, sunroof, and a rear window shade. But oil and antifreeze are mixing car is smoking coolant light on . Not knowledgable about this engine. Any help will be greatly appreciated thanks.
    Jaeger63 is offline Cadillac Owners Member
    Automobile(s): none
    Sep 2012
    Gatineau, Quebec
    23
    Re: New catera owner really need help
    That sounds like either a blown head gasket or a leaking oil cooler that is allowing the oil to mix with the coolant. Obviously you don't want to drive it like that until it's fixed and has fresh fluids. Coolant doesn't lubricate and oil doesn't cool, so running it like that will ruin the engine.
    Dec 2010
    Chicago
    247
    Not driving it only when I bought it but looking to repair it. Are the heads similar to the N* can it be done with the engine in the car? Where is the oil cooler ?
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    how many miles on it and its sport?????
    Dec 2010
    Chicago
    247
    75,000 wish it was a sport
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    oil cooler i have info about where and how to remove oil cooler but cant post here, to mush
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Blow by blow instructions with pix (courtesy of Omega Owners Forum)
    http://www.omegaowners.com/forum/ind...?topic=90596.0
    Dec 2010
    Chicago
    247
    Ok so I might have F*!} up. When I bought it I drove for about half hour then I noticed smoked for under the hood smelled like oil then the oil light. I added oil a lot. Then comes the white smoke. Little oil from the bottom I mean a drip or two not enought to cause constant oil burning while driving, no coolant leaks, but a milky oil cap. Hope it's not the heads will look at it this weekend.
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Not worth fixing. If you can fix it, invariably something else will go wrong.
    Dec 2010
    Chicago
    247
    Found a engine with 45 k on it put a 99 1300. Anything I should do before install?
    Automobile(s): none
    Sep 2012
    Gatineau, Quebec
    23
    Quote Originally Posted by 98Geldog View Post
    Are you sure you actually have a problem that merits an engine replacement? It's much cheaper and easier to replace an oil cooler than an engine. Have you done a compression or leakdown test? Do you have rod knock?
    Dec 2010
    Chicago
    247
    I think the thick white smoke blowing out the exhaust says it all. And no havent done the test and there is a rod knock faint but on cold start then goes away.
    Dec 2010
    Chicago
    247
    Just got my catera back today! New engine installed 45k 75k on the car. This thing drives pretty good. Still a couple issues. The coolant light is on which I think it's a faulty sensor in the overfill, it shakes a bit at low rpm the mechanic says its throwing a throttle body code, will scan tomorrow to see what code, of course I have radio issues but I got 2 relays from the bone yard that I resoldered and will test out tomorrow, both cigar lighters won't work and the fuse is good, the snow button is lit at all times? The sunroof wants to work goes up a little then shuts back sometimes in even and the car seems to want to veer to the right just a bit a times. Other than that I've hit the highway at about 100 and she wanted more, drives pretty damn good.
  16. #14
    Dec 2010
    Chicago
    247
    So the code is the random misfire codes. The guy installed new plugs so I guess I will be replacing the coils, think that's the best place to start she only shakes at low idle sometimes and while driving its fine. The resoldered relays so far work great no radio issues and my fog lights work now. Thanks for the info
  17. Remove Advertisements
