Lost Spedo, Odo, CC, etc.
Results 1 to 13 of 13
Cadillac Catera and Cimarron Forum Discussion, Lost Spedo, Odo, CC, etc. in Past Cadillac Vehicle Discussion; Let's just say this year's been particularly bad for my poor Catera, at least it gets me around for now, ...
    ducky69247 is offline Cadillac Owners Member
    Automobile(s): 1998 Catera, Kicker 300w Amp & 2x12" Kicker subs in trunk
    Feb 2011
    Needles, California
    35
    11
    Let's just say this year's been particularly bad for my poor Catera, at least it gets me around for now, but my latest problem is intermittent (or rather, intermittently they work as intended, but more often do not).
    No Speedometer, no Odometer or Trip Odometer, no Cruise Control, and "TC," (Traction Control) "ABS," and "Check Engine" lights remain lit.
    Taken while driving. (No, not by the driver :P)
    Occasionally, the lights all except for "Check Engine" will go off and the instruments function properly, but quite possibly less than 10% of the time.
    Any ideas?
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Re: Lost Spedo, Odo, CC, etc.
    Seems like something is wrong with the ABS module. Could start out by checking fuse #19 (since it is intermittent, might look for something loose rather than a totally blown fuse). Also check that the Alternator is giving at least 13.5 volts as the ABS is sensitive to voltage.
    Feb 2011
    Needles, California
    35
    11
    ABS has something to do with Odo/Spedo/CC?
    Feb 2011
    Needles, California
    35
    11
    Fuse #19 = Fan control relay?
    Nov 2005
    674
    Quote Originally Posted by ducky69247 View Post
    Try Fuse #19 in the fuse panel under the steering wheel, not the fuse panel in the engine compartment.
    Feb 2011
    Needles, California
    35
    11
    Are those numbered? How do I tell which is 19?
    Nov 2005
    674
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    ABS module. Common problem on this car. Dealer quoted me 1700-2300 for the parts and repair. However there is a company in Idaho that will rebuild it for 200 dollars and guaranteed it for 5 years. From upstate ny and back again, via fedex overnight, a total of 4 full days.
    2000GoldCatera is offline Cadillac Owners Member
    Automobile(s): 2000 Catera
    Nov 2013
    55
    17
    I had the same problem with my 2000, fuse 19 was blown changed fuse and all is better.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Its ABS module. I had the samething. U have to remove abs pump , disconnect module and send it to modulemaster.com to rebuild. I paid $120 for it. There are few videos on YouTube from the guy, just watch them.
    overplayed's Avatar
    overplayed is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera
    Nov 2004
    VA
    182
    I had mine rebuilt at BBA Reman for $60 through Ebay with free shipping and Lifetime warranty. My issues were intermittent also until it quit working altogether.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Catera uses the right rear wheel speed sensor for vehicle speed. That is measured by the EBCM (brake control module) and transmitted via the data bus to the other modules dependent on VSS.
    Your EBCM is dead, therefore no modules have vehicle speed, this sets multiple codes and makes the speedo not work, etc.
    They can be remanufactured, if you were to buy it new and have it installed the car is totaled.
    I've seen more than one owner call a tow truck and a salvage yard when they got the quote to repair it.
    w98seeng is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville
    Mar 2011
    54
    110
    Can't a faulty VSS cause these problems also?
    Ian
  16. Remove Advertisements
