shifter problem
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, shifter problem in Past Cadillac Vehicle Discussion; while driving, i accidentally bumped the shifter. Tranny did not shift and stayed in drive, but shifter moved into third. ...
    catera questioner is offline Cadillac Owners Member
    Automobile(s): catera
    Aug 2012
    3
    shifter problem
    while driving, i accidentally bumped the shifter. Tranny did not shift and stayed in drive, but shifter moved into third. i continued driving with no problem, but when i stopped the shiftter wouldn't move. now i can't shift into park, so car won't start and can't open trunk because of safely switches. car is still in drive according to the indicator light. i am about 200 miles from home and would appreciate any ideas on how to get the shifter back in synch with the tranny. thanks it is a 2000 catera
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: shifter problem
    Disconnect the battery. Turn ignition to off and put foot on brake and see if that helps. Try that in any sequence.
    Aug 2012
    3
    Re: shifter problem
    Thanks, I'll try that first thing in the morning
    Aug 2012
    3
    Re: shifter problem
    Disconnecing the battery did not change anything. Any other thoughts?
    Jul 2008
    712
    Re: shifter problem
    Something is out of position. Sounds like the shifter physically moved, but did not change the transmission setting. Linkage might be bent or loose.
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    Re: shifter problem
    The shifter is rivited to the floor the rod may have bent get under the car and take a look
  9. Remove Advertisements
