Chrome rims leak air
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, Chrome rims leak air in Past Cadillac Vehicle Discussion; On my 98 Catera all my tires have slow leaks in them and was told by father-inlaw that its our ...
    98Catera_2010's Avatar
    98Catera_2010 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Cadillac Catera Sport
    Oct 2010
    Cookstown, Ontario Canada
    28
    242
    On my 98 Catera all my tires have slow leaks in them and was told by father-inlaw that its our rims that cause it. He has owned 2 both with same problem and mine as well. Anybody else have issues or know for sure y? Been thinking of just getting new but I love the stock chrome rims.
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Re: Chrome rims leak air
    Yes, I had the same problem. Tried the bead leak stuff and only worked for few weeks....when it was time to change all my tires I told the tire shop to clean up / buff the inner rims really good and since then it has no leaks.
    Thanks.
    Oct 2010
    28
    242
    Nice. When I go pick up my tires ill tell them to do that next time. Thanks retho78
    Quote Originally Posted by retho78 View Post
    Sep 2007
    1,024
    You're welcome.....hope it works for you.
    kaustein is offline Cadillac Owners Enthusiast
    Jul 2008
    712
    Most all rims wil corrode along the tire bead. If they are busted off the the rims cleaned well and re-mounted, that should fix the problem. My craptera had the same issue. Tried Goodyear dealer, but got the best results at Sears.
    Mr12volt is offline Cadillac Owners Member
    Automobile(s): Catera
    Sep 2011
    1
    I had this problem on all four rims. The thing that solved it was putting in new valve stems WITH (this is the important part) RTV silicone gasket sealer in the groove where the stem seats against the rim. My rims do have a ton of corrosion around the tire bead but they seal just fine, its the vale stem that's the problem(in my case anyway.) You can test for this by mixing up some dish soap and water and spraying it on the valve stem. Wait 5 minutes and see if it bubbles up. Getting the valve stems replaced at a shop should be really cheap, they don't even have to take the tire off the rim. They can just squash the tire down near the valve stem, pull the old one out, spread the RTV goop on the new valve stem, pop it in, pump air back in the tire, done. Should cost about $10.
    I tried the tire bead leak stuff but it didn't work.
  9. Remove Advertisements
