help Catera misfire nightmare
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, help Catera misfire nightmare in Past Cadillac Vehicle Discussion; need help. 1st time on site luv it. installed new camshaft covers, and plugs, seemed simple, but when i started ...
    skippy11 is offline Cadillac Owners Member
    Automobile(s): 1997 catera
    Aug 2012
    1
    Questionhelp Catera misfire nightmare
    need help. 1st time on site luv it. installed new camshaft covers, and plugs, seemed simple, but when i started cat she acted like an engine thats timeing is retarded backfireing slow turnover all that even some smokey exhaust. took it all apart again makeing sure fireing order was correct plug gaps right, retorqed intake,plenium throttle body,cleaned oily plug boots boot holes out with alchohal,cleaned oily crank pos. senser off with alco. and reinstalled. checked for codes with obd 2 scan. got none just 00 and err 2 . restarted after all this engine then turned with more authority tried briefly to start but backfired a little and emmited smokey exhaust. pulled back timebelt cver belt not broken. help pleasehelp catera nightmare
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Re: help caera nightmare
    Was the car running when you started this work or are you trying to get a car going that you just got?
    What did you get when you scanned for codes? What do you mean by 00 and err 2? Doesn't sound like the scanner successfully made the connection. You need those codes. You probably have misfires and you need the codes to find out which cylinder. When you disturb old brittle ignition wires to change plugs, you can break them internally.
