Yet another oil leak and window regulator question
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, Yet another oil leak and window regulator question in Past Cadillac Vehicle Discussion; The window question is rather simple, anybody have a window regulator (full assy) compatible for a '99 rear/driver they're willing ...
    PrimeTimeElite's Avatar
    PrimeTimeElite is offline Cadillac Owners Member
    Automobile(s): Catera 1999
    Dec 2005
    Colorado
    39
    QuestionYet another oil leak and window regulator question
    The window question is rather simple, anybody have a window regulator (full assy) compatible for a '99 rear/driver they're willing to sell?
    Oil - I've replaced my valve covers twice (believe the Opel forum guy when he says get the OEM gaskets - or you WILL do it twice) but I still have a leak. It's further down and causes a decent smoke out (particularly on the drivers side) when it hits the exhaust. Any thoughts? Better, anybody have any luck with leak detection kits DIY?
    TIA
    01Cat is offline Cadillac Owners Member
    Automobile(s): 2001 Catera
    May 2010
    63
    10
    Don't waste your time with those warped plastic cam covers, get a junkyard Saturn metal set and be done with it. you have to buy two rear ones without the oil fill neck and put oil in it with a dipstick funnel. Only takes 20 seconds per quart and no more leaky valve covers.
    Second best thing i ever did for the car, the first was bypassing the oil / water heat exchanger so it can never fail. U can do that from below, right above the oil filter canister and never have to open the top of the engine.
    Dec 2005
    Colorado
    39
    Re: Yet another oil leak and window regulator question
    Interesting concept, but at the moment the valve covers aren't part of the issue (at least for now). I may have to try your solution if they do creep back up again.
    Any other thoughts on the leak I do have?
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Is it coming from the oil cooler?
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    I would check the oil cooler or the oil cooler lines
  8. Remove Advertisements
