more airbag questions - please respond.
Results 1 to 5 of 5
Cadillac Catera and Cimarron Forum Discussion, more airbag questions - please respond. in Past Cadillac Vehicle Discussion; Hi, I found the airbag issue of the '01 catera to be: 1- missing driver airbag, so I got one ...
    liweih21 is offline Cadillac Owners Member
    Feb 2012
    45
    Hi,
    1- missing driver airbag, so I got one off ebay
    but when testing with a good airbag, got u1000
    found may need airbag module - couple more questions.
    is there a difference between 97-99 or 00-01 for the metal box airbag module- I see part#
    90 564 341
    also, is the SDM the same as the airbag module?
    does the airbag module must be reprogrammed?
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: more airbag questions - please respond.
    Who did you buy it from, sans the airbag?
    Feb 2012
    45
    ebay
    Help answer my other questions
    Jul 2008
    712
    Got me on the airbag question.
    Feb 2012
    45
    Ok, did some research, I will attempt to get the SDM reprogrammed.
    As far as the airbag light ON is concerned - how does it work?
    When the car gets in a slight accident in front bumper, how does it set off the driver airbag?
    is there actual sensor in the front bumper?
    If one changes the SDM/airbag module and reprogram will that resolve the airbag light, assuming driver side, passenger side, seat bags, belt tensioners and side sensor glued to both front doors all works?
  8. Remove Advertisements
