airbag issue, driver bag was missing, after change it, b1000.
Results 1 to 2 of 2
Cadillac Catera and Cimarron Forum Discussion, airbag issue, driver bag was missing, after change it, b1000. in Past Cadillac Vehicle Discussion; Hi, it appears the previous owner did some foul play, I found the air bag light is on after changing ...
    liweih21 is offline Cadillac Owners Member
    Feb 2012
    45
    Hi, it appears the previous owner did some foul play, I found the air bag light is on after changing the airbag bulb - 01 catera.
    Took to mechanic and found driver airbag missing, he found a direct replacement one and test with it, then got B1000? communication error? is this the main airbag comp? where is it? how can I replace it myself?
    Also, is there a impact sensor in the front bumper? I see a crease in my front bumper? but we conclude the driver airbag removed since maybe it deployed?
    Lastly, is there a way anyone can disable the driver seat airbag? I see a very thin white plastic wire-line (no connector in end) sticking out behind driver seat.
    Feb 2012
    45
    Re: airbag issue, driver bag was missing, after change it, b1000.
    no one has airbag b1000 issue here ever?
