Results 1 to 7 of 7
Thread: AC line connector question. Tools?
    jupiter57 is offline Cadillac Owners Member
    Automobile(s): '97 DeVille, '98 DeVille, '97 Catera
    Feb 2005
    Lancaster, Kentucky
    Found a leak in my '97 Cat AC Condenser tube,
    http://www.oehq.com/Partpix/ACDjpg/15-33344.jpg
    I just got a replacement, but I have no idea how to disconnect the line with the little green tabbed "cap":
    http://www.oehq.com/Partpix/ACDjpg/15-31026.jpg
    This is the first time I have encountered such a fitting. It looks complicated.
    Any special tool to use for this? Tips, tricks, etc.?
    My Google skills have yielded no results!
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Re: AC line connector question. Tools?
    I think there's a special tool to disconnect the lines. Maybe this tool might work.
    http://www.harborfreight.com/6-piece...ool-97576.html
    http://www.amazon.com/Lisle-37000-Co.../dp/B0002SRCK6
    Feb 2005
    Lancaster, Kentucky
    Thanks, retho!
    I actually have a set of each of these, (and other types of disconnect tools) but the pic above showing the snap ring is kind of throwing me off!
    Here is a couple of pics of a similar one (this one goes into the Evap.)
    http://s39.photobucket.com/albums/e1...Fitting002.jpg
    http://s39.photobucket.com/albums/e1...Fitting001.jpg
    I cannot see any way to get the disconnect tool past the green "cap", obviously it has no clearance.
    Wondering if that green cap comes off? I have tried screwing it off in both directions, pulling gently, and squeezing it to no avail.
    (Don't really want to break something, the fitting packs are ~$30 ea., and there are 3 involved in order to remove all the lines, need be.)
    Even ALLDATA gives me no direction!
  5. #4
    Sep 2007
    1,024
    It does come off per the Catera service manual and it also shows the all the quick connect o-rings and locks. It only says to remove the quick connect fitting from the evaporator tube extension :-(. Also, have you tried squeeze and turn together?
    Thanks.
  6. #5
    Sep 2007
    1,024
  7. #6
    Sep 2007
    1,024
  8. #7
    Feb 2005
    Lancaster, Kentucky
    Well, still can't figure out how to get this off, so I just ordered 2 new ones:
    http://www.gmpartsgiant.com/parts/gm...-90543326.html
    $11.40 ea vs. $27.XX!
    Figure that once I get the kit, I can possibly figure them out! LOL
    I'll live with the leak until they arrive, temps here in the 90s every day, gotta have my A/C!
  • You may not post replies
