98 Catera problem, figures. Can you tell me whats wrong?
Results 1 to 14 of 14
Cadillac Catera and Cimarron Forum Discussion, 98 Catera problem, figures. Can you tell me whats wrong? in Past Cadillac Vehicle Discussion; I got a '98 Catera, and everytime I start it up, it makes a whine type of noise in the ...
    TehKevster is offline Cadillac Owners Member
    Automobile(s): 1998 Catera(gone), 2002 Deville
    Jul 2012
    26
    21
    I got a '98 Catera, and everytime I start it up, it makes a whine type of noise in the front end of the vehicle.
    It does this for minute or so, I believe it has something to do with the front air shocks because I can't go more than 3mph on one of our towns railroad tracks, or any bump for that matter, but I can't figure out where to start looking to find out what's wrong.
    I'll try to get a video up, unless someone has had this issue and knows what needs to be fixed..
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Re: 98 Catera problem, figures. Can you tell me whats wrong?
    probably power steering pump or alternator. Try to turn the steering wheel and see if it makes any noise.
    cadmanchris's Avatar
    cadmanchris is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 DTS,2007 STS V8
    Dec 2006
    New Jersey
    44
    601
    The noise is the air pump for the emissions system. There is also an level ride compressor in front. But these 2 things will not limit your speed to 3 mph. Is check engine light on?
    Jul 2012
    26
    21
    Alright, I managed to make a video, you can check it out here, and hopefully tell me what you completely think it is so I can get looking and fixing.
    http://www.youtube.com/watch?v=OBT5l4Kx7wE&feature=plcp
    And as for the 3mph, I meant that like if I go any faster it's so rough and it seems like the shocks are not doing what they should be.
    Sep 2007
    1,024
    That sounds strange....can you open the hood and take a video so maybe it might help to track the noise better?
    Jul 2012
    26
    21
    Alright, I'll have a video up in a few.
    Jul 2012
    26
    21
    Alright here is another video with the hood up.
    http://www.youtube.com/watch?v=PXi8W...hannel&list=UL
    It sounds like it's coming from under or behind the battery from what I heard.
    Sep 2007
    1,024
    I have a doubt it's the tensioner pulley or maybe the AC pulley grinding against the compressor clutch.. Try spraying some WD40 or maybe add two or three drops of all purpose lube to the bolt/center area of the pulley and see what it does. Also, does that noise happen with the battery just turned on?
    CADMAN56 is offline Cadillac Owners Member
    Nov 2008
    15
    Sounds like AIR pump running and leaking air. Check pump assy for leaks when it is running,also check hoses and diverter valve for leaks.Pump is under left front of car,valve is mounted to radiator at top left
    Jul 2012
    26
    21
    Does anyone have a diagram or something as to where all of the hoses are and lead to? I'm sure it ought to be one of those, and if I knew where to look I could lift the Catera up and check at startup for the problem.
    Jul 2012
    26
    21
    Alright, I got a 3 book service manual for a 1998 Cadillac Catera. And it shows that only the back of the vehicle is meant to lift. Relief to me, but opens up many more questions that I have to figure out. I don't believe my struts are bad, because I can push down on the front of my vehicle and it will go down and rise back up like it's supposed to do. As for the noise, I may have to look into it, but it doesn't seem to do any harm as there is no front air ride. Post as you please, I'll put updates up as they come.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by TehKevster
    That tells you exactly nothing about the condition of the struts. Struts (and shocks) absorb shock, and control body motion, your car is suspended by coil springs, they are what pushes back up when you push the car down. Uncontrolled body motion, "pogoing" up and down after hitting a bump, bottoming out....those are signs of bad dampers.
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    How heavy is the spring rate to the strut??
  16. #14
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    its secondary air injection pump got unseal and pumping air around it. that pump look just like vacuum cleaner motor, and makes almost the same noise
    located right under front driver side bumper, its right next to horn, u lift vehicle remove horn, remove pump and resealed with 5-6 long screws, original screws (they look like calipers) got broken
  17. Remove Advertisements
