Results 1 to 4 of 4
Thread: 1997 Catera/ Oxygen senser, senser 1, bank 1 code
    jpgrod is offline Cadillac Owners Member
    Automobile(s): catera
    Jun 2012
    30
    9
    Hello my cater has beed starting then after I drive it won't start again . It's been doing this for 2 weeks know I saw on here about changing the CPS so I did but still starts drive but when I shut it off it won't start just cranks like it doesn't have any gas going to the engine . Well my buddy came over read my codes it said O2 senser 1 bank 1 . So will this really make my car not start cause to me it feels like the gas lines are clog or like I said no gas is getting to the engine . I sprayed engine starter but it starts but dies then just turns over but no gas. Well any I deas I though about the fuel pump but I though once they go they go ! Thanks in advance !
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    The O2 sensor isn't causing your no start issue.
    Next time the car won't start, remove the gas cap, put your ear to the opening, and have a friend turn the key to the ON position. Do you hear the fuel pump whirring? Better yet, hook a fuel pressure gauge up to it next time it won't start.
    Jun 2012
    30
    9
    Re: 1997 Catera/ Oxygen senser, senser 1, bank 1 code
    I did do that and I did not here a thing but I was told that the fuel pump does not stop then start I heard once it dies it dies . But ya I did not here anything no swirl or nothing so maybe it is the fuel pump I will check again in the morning I was tired at the time I call some freinds to ask ther opinion if they hear it ! I must say also now it wont even crank on it use to turn on but die now just the start cranks ! thanks
  5. #4
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Nov 2009
    Rochester NY
    37
    449
    How full is the tank when this happen? does it happen EVERY time?
    does the car every stall while driving? or does it simply not want to restart each and every single time?
  • You may not post replies
