Low Oil Pressure
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Like Tree1Likes
Cadillac Catera and Cimarron Forum Discussion, Low Oil Pressure in Past Cadillac Vehicle Discussion; I was driving to work today and suddenly on red light got beep noise, look at the dash board and ...
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Low Oil Pressure
    I was driving to work today and suddenly on red light got beep noise, look at the dash board and saw light at the low pressure gauge and gauge was on 0psi (red zone) i pulled over, restart vehicle and got same thing - 0psi !!!! Then vehicle was seating park for 4 hours. when I started, gauge was showing 80psi, then in around 5 min driving when car got worm, gauge start to showing around 15-20psi almost at the red zone!!! After few more minutes, I puled over at the parking lot and got beep again gauge was showing 0psi (red zone) at 600-700rpm.
    When I driving it's stays in around 20-60psi zone. When I setting on park and just accelerating to 1500-2000rpm gauge jumping to 20-40psi.
    PLEASE HELP !!!!!!!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Is your oil level correct? If so, if so, have the pressure checked with a gauge to rule out a faulty oil pressure sender.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Low Oil Pressure
    catera's have been known to have problems with oil pressure and oil pressure switches
    depending on the exact model (year) there are a couple different things that could be the problem
    they are pretty well documented here if you do some searches
    there should be at least 3 very long threads with a few people that swam through the swamp that you are just now dipping your toes into
    good luck
  5. #4
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Maybe cleaning the oil pressure sensor with a sensor cleaner should work. It's in the front of the upper oil pan (left side), right below the pulley. If that does not work then try adding a little more thicker oil.....thanks.
  6. #5
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    today i went to junk yard and got switch from 113k Catera, mine is 2000 Sport with 148k on it
    so replacing took me just 5 min but i have same situation, its going to red zone in 5-10 miles drive
    my switch cost $222 in Auto Zone, $145 on ebay thats really high for damn switch
    one from junk yard could be bad too but its like 99.9%
    i will try to test with gauge tomorrow
    but if any body know something about
    PLEASE HELP
  7. #6
    Sep 2007
    1,024
    Did you try cleaning it with the sensor cleaning spray? Make sure to clean the tiny hole on the tip of the sensor part where it threads into the upper pan. If that doesn't work, then drain the old oil and add 10w40 and see what it does. If nothing works, my guess is that the oil pump is failing.
  8. #7
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    He's what I did when I had the same problem, change oil and filter, change oil pressure senor ( at The dealer it cost me $86.00 I don't were these guys are coming up at $100.00s) now it goes from 60psi when running and 20-25psi when stop. if that does not fix it then you lost your oil pump.
  9. #8
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Quote Originally Posted by gvjv3 View Post
    One vital piece of info is missing. What weight oil are you using? I had similar issues and treated by switching to a 10W40 or 20W50 oil during the hot summer months. The high ambient temps thin the oil and the heavier weight doesn't seem to be affected. The only time I see the red warning light is upon initial start up. Just a wink. I switch back to a 10W40 or 10W30 for the winter.
  10. #9
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Quote Originally Posted by elvin315 View Post
    The thing that is more troubling with his problem is that the gauge dips to 0. As you said, I had the problem of the oil pressure dropping slightly below 20 psi at idle on extremely hot days two years ago and "fixed" it by using some STP oil treatment which is mostly 50 weight oil. Didn't have to use it last summer at all. But never did the pressure drop to 0.
  11. #10
    Sep 2010
    East Boston MA.
    29
    26,325
    This advice is all over this forum (and many others). Low oil pressure indicates low oil volume, and THAT'S the important part. Switching to a heavier weight oil is NOT a treatment or a fix, it simply masks one of the symptoms, the low pressure reading. The pressure only increases because the thicker oil is more difficult to pump through the oil passages, it does not increase flow, it does not solve the problem.
    Instead of trying to diagnose the pressure sender, have an actual oil pressure test performed (using the correct viscosity oil), and go from there.
  12. #11
    May 2012
    119
    what oil I used is 10-40W Full Synthetic (always use Synthetic) cost more but if you don't problems will arise, and one Quart of Lucas
  13. #12
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Changing the oil may not be a fix but it is cheaper than throwing hard parts at the problem.
  14. #13
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    PROBLEM SOLVED !!!!!!!!!!!!!!!!!!!!!
    Oil had coolant in it due to previous problem with Heater Control Valve that got broke in side and was pushing coolant in air hose where was mixing with air, then with fuel in cylinder, and was giving me multiply misfire. Heater Control Valve and coolant was replaced but wright after that, got that low oil pressure like on the day i left shop that was dealing with me misfire. So i just drain oil for like an hour and filled with (Walmart Super Tech 15W-40, AcDelco filter). Now works fine. i still not sure if 15W-40 fixed the problem but i can tell when I was draining oil it was really thin just like Coca-Cola and oil cap was look like i got blow head gasket.
    I will still track result. And will post any changes
    Thanks to every body !!!!!!!
  15. #14
    Sep 2010
    East Boston MA.
    29
    26,325
    Right, but you accomplish exactly nothing. The pressure increase does not mean increased oil flow, the problem remains the same, the needle is just in a different position. It's like putting a piece of tape over the check engine light.
    A sufficient amount of oil must be pumped throughout the engine in order to properly lubricate the bearings, correct? Think of it this way:
    You're filling up a pool with a garden hose. The hose isn't long enough to reach the pool, but the stream of water can reach. Now turn the spigot down a little. Pressure in the hose drops, and the water no longer reaches the pool. Now if you switched the water supply to something thicker, let's say cooking oil (not the most pleasant thing to swim in, but for the sake of argument...) pressure in the hose will go up, but since FLOW doesn't increase, the oil still doesn't reach the pool.
  16. #15
    Sep 2010
    East Boston MA.
    29
    26,325
    Absolutely, 100% FALSE. There are very few engines that actually require synthetic, and the Cateras is NOT one of them. The non synthetic oil recommended in the owners manual, in the recommended viscosity, from any brand, will work just fine.
    Does synthetic oil have advantages over conventional oil, and is it "better"? Yes.
    Is it necessary/required? In the Catera, no.
    Since when does engine oil need "stabilizing"? Can you explain exactly what that means? It's advantages? Can you explain why NONE of the worlds automobile or engine manufacturers recommend its use?
  17. Remove Advertisements
