Low Oil Pressure - Page 2
Results 16 to 30 of 34
Like Tree1Likes
Cadillac Catera and Cimarron Forum Discussion, Low Oil Pressure in Past Cadillac Vehicle Discussion; Originally Posted by JohnJJO filled with (Walmart Super Tech 15W-40, AcDelco filter)........ not sure if 15W-40 fixed the problem The ...
  1. #16
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by JohnJJO
    The thicker oil didn't "fix" anything, and 15W-40 is TOO HEAVY for an engine designed for 5W-30/10W-30.
  2. #17
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    Re: Low Oil Pressure
    Yoo! with a Catera with 150K+ miles on it and you want to make it to 200K miles you need to add whatever helps, of corse not new cars, put in cheap oil you get cheap results, put in good oil and you have no problems with you car at high mileage like i do.
  3. #18
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Well actually this is first time i filled Walmart brand in it, i was just trying so see whats gonna happened with 15W-40. but since i got car 2 (years ago) i filling only with Castrol GTX Hight Millage 5W-30. and also was planing to drop to Castrol 10W-30 againe in 100 more miles and basically use that cheap 15W-40 just for temporary.
  4. #19
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    if you have oil in the coolant, most likely the oil cooler is bad.....thanks.
  5. #20
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    Its to heavy how much does it weigh???
  6. #21
    Sep 2010
    East Boston MA.
    29
    26,325
    Heavy, as in too high a viscosity.
    "Heavy" gear oil.
    "Light"machine oil.
    What "weight" oil does my engine require?
    Common terminology.
    SAE 30, 5W-30, 20W-50, etc....are all SAE weight designations.
    Oils that contain polymers that allow them to change viscosity depending on temperature (5W-30, 10W-30, etc....), are multi weight oils.
  7. #22
    Sep 2011
    Plainfield ILL
    59
    139
    Wow so i ask again how much does it WEIGH
  8. #23
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Quote Originally Posted by hemic05 View Post
    oil weighs 7.5 lbs per gallon or 1.875 pounds per quart.
    I learned the rhyme "A pint's a pound the world around" was I was a tot. Almost any liquid weighs approximately a pound per pint. Water is a bit more, oil a bit less.
    I
  9. #24
    Sep 2010
    East Boston MA.
    29
    26,325
    I thought you were asking if by "too heavy" I meant actual weight.
  10. #25
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    after week driving i don't see any problems
    1 picture. - reading on hot engine (seating on "park" gear)
    2 pic. - reading on cold engine (just when i start the vehicle)
    3 pic. - reading on hot engine (1000 rpm seating on "park" gear)
    4 pic. - reading on hot engine (going 50mph) by not holding gas pedal
  11. #26
    Sep 2010
    East Boston MA.
    29
    26,325
    Are you still running the 15W-40?
  12. #27
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    55,584
    Quote Originally Posted by investor74 View Post
    oil weighs 7.5 lbs per gallon or 1.875 pounds per quart. I learned the rhyme "A pint's a pound the world around" was I was a tot. Almost any liquid weighs approximately a pound per pint. Water is a bit more, oil a bit less. I
    fresh water = 8.32#/gallon
    sea water = 8.56#/gallon
    diesel = 7#/gallon
    gasoline = 6#/gallon
    Lube oil = ~7.35#/gallon
    You utilize all this trivia when you're trimming a submarine for neutral buoyancy while 800 feet down................"Chief Of The Watch, flood 1,000 pounds to auxiliaries from sea !"
  13. #28
    RPerry435 is offline Cadillac Owners Member
    Dec 2011
    Saginaw,MI
    32
    56
    Synthetics dont break down and create slug in the engine. that enough of a reason all by itself for me. I can almost GUARENTEE that our car came with full synthetic from the dealership.. as far as fuel octane goes, lower octane specifically lowers the performance of the engine and that IS in the manual.
    odds are what you saw on your oil cap was from when the motor only warmed up enough to create some condensation thus creating what you saw. usually happens when it gets colder out. just my two thoughts
  14. #29
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    36
    449
    I agree!!! my father use to put 20w50 into all his "old" cars cause of low oil pressure, and every single one would get bearing knocks... i would only use what is recomended in the car. if it is the oil pump failing (and sounds that way) adding a thiker oil will only make the oil pump work harder and go faster. It really sounds like a oil pump. It seems the sensor is working. i did notice lower pressure when I was 2 qts down in my catera, but Never had a 0 psi read... its 12 yrs old. 150K. I would not continue to test drive it.. its worth an oil pump.
    Sorry I ment to referance the post about not useing thinker oil.. bt moistcabbage or rethro...
  15. #30
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Hello that me again. and i still using 15W-40 its sill runs grate but my gas millage went down, but it can be related to gas that i use now i went to highest octane (premium) at the same time i start to use 15w-40 and getting only 200miles on full tank (
  16. Remove Advertisements
