2000 cadillac catera
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, 2000 cadillac catera in Past Cadillac Vehicle Discussion; My break lights went out and they will not come back on so I went to my mechanic and he ...
    MCOLE is offline Cadillac Owners Member
    Jun 2012
    1
    My break lights went out and they will not come back on so I went to my mechanic and he thought it was a fuse blown because it wasn't catching any power so he started replacing the fuses located under the steering wheel and the break lights still would not come back on then the car won't crank back up he has tried replacing the ignition switch but that wasn't the problem its giving spark but will not crank PLEASE HELP
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    Re: 2000 cadillac catera
    moved from cust svc
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    This is logical. The brake lights don't work so your "mechanic" randomly replaces fuses and when it won't start up again he replaces the ignition switch. How can anybody on this board help you at this point? Who knows what your mechanic did?
    Now we'll get a post from someone saying the Catera is crap, etc.
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    The car is crap! However check the crankshaft positioning sensor. Common problem. This board will help you with most of your problems, but some of the members who are here are very thin skinned and can't take any criticism of the car.
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    if car cranks and does not start its is not ignition. I suggest CPS as kaustin said. Sometimes the car needs a reset when stuff is messed with. Id try disconect battery sit and reconnect.. thats simple. may or may not help.
    The ignition needs to be programed tot he car is changed I do belive. Id reinstall old one.
    There is a brake control swith that is prolly bad (for brake lights) common issue.. I have seen postbefore... I never had that issue myself. maybe a lil help fom somone about that??
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Instead of GUESSING, you could always PULL THE CODES. Has anyone checked the fuel pressure?
  9. Remove Advertisements
