How cold is your Catera A/C?
Results 1 to 10 of 10
Cadillac Catera and Cimarron Forum Discussion, How cold is your Catera A/C? in Past Cadillac Vehicle Discussion; Hi, I'm curious to know how cold the A/C in your Catera blows. I have added refrigerant and checked it ...
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    Hi,
    I'm curious to know how cold the A/C in your Catera blows. I have added refrigerant and checked it with an AC thermometer and showing around 58deg, not sure if that is normal.
    Thanks.
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    Re: How cold is your Catera A/C?
    No thats not normal it should be around 42
    Sep 2007
    1,024
    Okay, thanks. What should I do now....added refrigerant with the handheld pump and can, shows 45 on the pressure gauge. Also, if the compressor is weak could that be the issue. It works fine but not sure if that's I can't get it lower than 58 degree Fahrenheit.
    kaustein is offline Cadillac Owners Enthusiast
    Jul 2008
    712
    58 degrees maybe good if you are using outside air and it's 105 degrees outside. Check temp on recirculating mode and compared the outside temp. Then turn on ac and see what the difference is. Your ac maybe good, but the out air plenum may not be functioning properly, or the heat may not be shutting completely off. Or you have a ref. leak.
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    36
    449
    my catera never blew super cold either. I had to have it on max all the time... still never got cool enough unless it was an hour long drive.
    BTW its not a good idea to let the car idle on a hot day with air on. the heat will overheat the starter, and when you shut the car off it will not restart. the car will have to cool down befor it will restart.
    I know this from expierance.
    Sep 2007
    1,024
    The AC thermometer shows only 58 deg on the vent. I'm not sure what the problem is but it blows pretty cool air even with temps between 85-95 deg outside. My guess is to check if the thermometer is working properly or maybe have to add more refrigerant. How much does refrigerant does it take?
    Thanks
    Sep 2011
    Plainfield ILL
    59
    139
    I think about 2 1/2 pounds
    Sep 2007
    1,024
    Okay, so added some more refrigerant today and drove the car around. The temp outside was 106 degrees and the AC gauge thermometer showed between 40-42 degrees. So I guess it's working good now.
    Thanks.
    Sep 2011
    Plainfield ILL
    59
    139
    Great to hear hope it stays nice for you
    Sep 2007
    1,024
    Yes, it's working well. I felt very cold this morning when it was 86 outside and this afternoon it is 107, nice and cold air blowing from the AC :-).
  13. Remove Advertisements
