No Brake lights?
Results 1 to 3 of 3
Cadillac Catera and Cimarron Forum Discussion, No Brake lights? in Past Cadillac Vehicle Discussion; Hello I have no brake lights and the fuse box shows all fuse's good, there is a fuse for the ...
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    QuestionNo Brake lights?
    Hello
    I have no brake lights and the fuse box shows all fuse's good, there is a fuse for the STOPLAMP SWITCH, can anyone tell me where that switch is?
    Thank You
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: No Brake lights?
    it's under the driver's side dash, behind the brake pedal lever.
    Advanced Auto Parts - #SL72001 (approx $25)
    Doctur J is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac Catera
    Mar 2011
    7
    Be careful the cruise control switch is located there as well. Press the brake pedal down as far as you can, feel under near the brake pedal shaft and you will feel two plungers. The top one is the stop light switch! It has a four wire attachment. I broke mine off to replace it, so be careful to break the one with the TOP plunger. I had to drill out the rest of the plastic to get it ready for the new switch.
    Once you get it all out, look at the new switch. Feel underneath where the switch need to be replaced-you will feel a slight cut in the mounting hole on the left. That will keep you from getting frustrated trying to insert the new switch. If needed, shave a little off the new switch and it should snap in.
    Once you have it mounted,wires connected, you should be set.
    If you cannot shift from park (brake to shift), peel off the shift boot, press the yellow tab and you can shift all gears. I had to take the latch on the park safety and wire the latch so that I could shift w/o problems-you may have to do likewise and I don't miss it. I have brake lights again! P.S You can purchase the switch from O'Reilly's for $20.00
