0il pan removeal?
Results 1 to 6 of 6
Cadillac Catera and Cimarron Forum Discussion, 0il pan removeal? in Past Cadillac Vehicle Discussion; Hello help please 1997 catera so there are 2 pans one small in the front of the main one, how ...
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    Questiontranmission fluid?
    Hello help please
    1997 catera so there are 2 pans one small in the front of the main one, how many quarts does the tranny take? and do I fill the small pan before putting back on? is there a filter or screen inside?
    sorry no manual to go by.
    Thank You
    Mr. G
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    Re: tranmission fluid?
    Drain both pans the filter is located in the rear pan use dexron111 to refill
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    May 2012
    119
    Question0il pan removeal?
    Does anyone know if there is a oil screen inside the oil pan of a 1997 cadillac catera?
    Thank You
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Re: 0il pan removeal?
    here is some pictures from all data
    1 picture - oil pan
    2 picture - oil Baffle Replacement
    Oil Pan Replacement:
    1 Raise and support the vehicle. Refer to Vehicle Lifting.
    2 Remove the 4 splash shield bolts.
    3 Remove the splash shield.
    4 Drain the engine oil.
    5 Disconnect the oil level sensor connector.
    6 Remove the oil level sensor wire electrical connector C-clip (1) from the upper oil pan.
    7 Remove the lower oil pan bolts.
    8 Remove the lower oil pan from the upper oil pan.
    9 Pull the oil level sensor electrical connector from the upper oil pan.
    10 Remove the oil level sensor bolts (if applicable).
    11 Remove the oil level sensor from the oil pan (if applicable).
    12 Clean the oil pan.
    13 Clean the oil pan gasket surfaces.
    Installation Procedure:
    1 Install the oil level sensor to the lower oil pan (if applicable).
    2 Install the oil level sensor bolts (if applicable). Tighten the oil level sensor bolts until fully seated and not stripped.
    3 Install the oil pan gasket.
    4 Install a new oil level sensor connector O-ring and lubricate with engine oil.
    5 Support the lower oil pan.
    6 Install the oil level sensor electrical connector through the upper oil pan and retain with the C-clip (1).
    7 Install the lower oil pan to the upper oil pan.
    8 Install the lower oil pan bolts. Tighten the oil pan bolts to 8 Nm (71 inch lbs.).
    9 Connect the oil level sensor electrical connector.
    10 Install the splash shield.
    11 Install the 4 splash shield bolts. Tighten the splash shield bolts until fully seated and not stripped.
    Do not strip the splash shield bolts.
    1 Lower the vehicle.
    2 Refill the engine oil. Refer to Capacities -Approximate Fluid.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    transmission fluid need to be change 50-60k if u want keep your transmission running smooth and extend life time. but u definitely need to change oil if u get 100k on catera!!! im not recommend to change it by your self, if its reached over 100k!!!!!! that transmission is "sealed" type, its need to be flushed!!! with special machine that shops own. they also will change filter and gaskets. but u be fine if u will do it by your self ONLY if u will get oil from dealer!!! will replace filter and gaskets but between 50-60k ONLY!!!
    just like i said !!!! if its reach 100k or over u need to do Flush or u will damage transmission. Also for u to know its not that easy get right level on that type of transmission.
    there is two oil pans. one have filter in it, second pan - where all solenoids located and pan have refilling plug. when u take down smaller pan replace filter and gasket, refill with new oil (from dealer) alway up before u screw it back.
    second pan, when u drop it down just drain it and replace gasket, then refill until oil will start to come out from plug. screw plug back, drive for a few miles until oil will get hot, let car seat for 1 min. and then check level (oil should be even with refiling plug) if oil coming out let it come out, if it's low and now even with refilling hole just add oil (but when u check level your whole car have to be even!!!! with rear, u can't lift front cuz oil level will not be right on level for u to check !!!!!) AND last. just like I said that kind procedure u can do by your self only between - 50-60k if it over 100k take it to shop for flush !!!!!
  9. Remove Advertisements
