Rear shock replacement
Results 1 to 10 of 10
Cadillac Catera and Cimarron Forum Discussion, Rear shock replacement in Past Cadillac Vehicle Discussion; I have heard that you can replace the rear shocks on a Catera with shocks for a new series GTO ...
    jimbrunton is offline Cadillac Owners Member
    Automobile(s): 2000 Catera
    May 2012
    Tampa, Florida
    3
    I have heard that you can replace the rear shocks on a Catera with shocks for a new series GTO specified shocks. Does anyone know if you do this does the "Leveling" light go out on the dash?
    Thanks
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: Rear shock replacement
    Before attempting, make sure you have no broken springs
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Yes & No. The GTO shocks fit but you lose the self-leveling feature and the light stays on. There are a few ways to disable the self-leveling thus killing the light. The simplest is to move the locating key on the rear swing arm. Drawing courtesy of CateraMV6:
    http://www.cadillacforums.com/forums...ml#post1998710
    Photo courtesy of CateraMV6:
    http://www.cadillacforums.com/forums...ml#post1998907
    You can also swap the GTO springs over. They'll lower the Catera approx. 1 inch.
    NOTE: the front GTO springs are swappable but not the struts.
    JBCadi is offline Cadillac Owners Member
    Automobile(s): Catera
    Sep 2011
    23
    I didn't realize changing to the Monroe MA825 air shocks that I would lose ALC. My original problem was after 20 minutes the Leveling light flashed constantly. I swapped the shocks (the fittings to the air line are not the same so I used vacuum line near the factory 'T' connection - source air line and 2 shock lines come together near the rear passenger shock). Now, when I start the car, the Leveling light is on constantly, then after 15-20 minutes starts to flash. I will check the air lines with soap/water spray but it looks like I have to adjust the tab as shown above. I still want the ALC to work or I would have replaced the air shocks with standard shocks. Any suggestions?
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    It sounds like you have broken springs causeing the car not to lift to correct level.
    I replaced my shocks with monroe shocks, and I by passed the auto fill system, and put an old school manual air valve to fill as I wanted it.
    But if you adapted the nipple fromt he factory system to fit your monroe shocks it will work.. so if it is all hooked up proper with no leaks, it is your springs.. prolly the bottom coil is broken off. Both of mine where.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Deleted.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    there is leveling sensor on rear column. who analyze level and giving order to air compressor to pump that located up front on passenger side. your sensor broke !!!! i have same problem. to replace it for new part it like $400!!! so when i installed Monroe MA825 i just pump them with my garage air compressor to 80psi (80psi it normal pressure for catera. i found in alldata)
    but i didnt connect shock line to catera system just between each other and used valve that was include in Monroe installation kit.
    to stop light flash i just disable sensor.
    globuslive's Avatar
    globuslive is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2000 & Catera 2001
    Feb 2011
    US
    164
    Hey guys. I installed today Monroe 825's. No issues, leveling works perfectly. what a problem did you have connecting original hoses to new connections??? All you have to do is to cut old end, put new or even keep old 1 O ring, and tight it to the shocks. That's all. No leaking, looks almost as original, and very tight ride. I love it so far. Will see how they go with the time.
    jhutchison05 is offline Cadillac Owners Member
    Jun 2016
    1
    Quote Originally Posted by globuslive View Post
    I have a Catera with 55,000 miles on it. I am need to replace the rear shocks. I purchased Monroe 825's and will install them this weekend. I hhas been a few year since you did yours. Thinking back is there anything I should watch out for?
    globuslive's Avatar
    Feb 2011
    US
    164
    Not really, they are pretty much same shocks as originals, the only difference is line connectors. If I remember right, there are two O rings you have to use, once you tight the nut, it will hold the pressure no prob. Just make sure there are no air leaks. Also I believe air outs designed a bit differently, so make sure lines are not jammed.
    PS. With those shocks I get level light flashes once under moderate load, which means, if I have 3 or more people in the car, after like one hour driving i get the level light on meaning overloading, but I think it's nothing to do with shocks, but with the pump itself. Still works tho.
    Also while u there, check the springs, they might be broken, usual thing when rear leveling shocks go bad. I had on both cateras same thing, replaced with Gto ones.
  13. Remove Advertisements
