Speedo and Tach not working, all other gauges and odo are fine, though
Results 1 to 9 of 9
Cadillac Catera and Cimarron Forum Discussion, Speedo and Tach not working, all other gauges and odo are fine, though in Past Cadillac Vehicle Discussion; Last week my speedo and tach stopped working while I was on lunch, but in the morning when I drove ...
    IvoryWhiteCatera's Avatar
    IvoryWhiteCatera is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Catera (SOLD)
    Apr 2011
    120
    Last week my speedo and tach stopped working while I was on lunch, but in the morning when I drove it to work it was just fine.
    They both stay at zero and once in a while it will start working again.
    All my other gauges and the odo are working perfectly fine, though.
    Any help will be much appreciated.
    Thanks.
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: Speedo and Tach not working, all other gauges and odo are fine, though
    Gremlins!
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    The speedometer is related to the ABS module, but that would not affect the Tach (as far as I know). Are you also getting an ABS light when this happens? Fuse 24 is for the Instrument Cluster - perhaps the fuse is loose.
    Apr 2011
    120
    No, I'm not getting an ABS light. It works occasionally. I'll check the fuses.
    ThatCoolDude is offline Cadillac Owners Fanatic
    Automobile(s): Catera Sport
    Feb 2011
    28
    115
    The same thing happens to my Catera when its really hot outside. If I can remember correctly someone on here mentioned it was the speed sensor, it makes a lot of sense since its right next to the exhaust. I know its from heat because when I get out of work after being parked in the shade it works but once I get home and turn the car off and then back on it doesn't work. This started back in the fall but it when away as the heat went away but it just recently started back up again so I'm more than likely going to buy the part. The speed sensor is cheap at rockauto.com $56 autozone.com $106.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Thats NOT a speed sensor!!!!!!!!!!!!.
    that ABS module !!!!! u have to remove ABS assembly. remove module and send it for rebuild !!!!!! its cost me $120 (u can find re-builders on ebay they even will give u 5 years warranty) i had same problem it was failing when car get hot, and then in few week its started failing all the time!!!! its pain-ass to remove ABS but it will work
    Apr 2011
    120
    @JohnJJO
    @ThatCoolDude
    Thanks. I live in Nevada and I notice that it works at 7 in the morning, but never during the day. But now, it RARELY works.
    RayJs is offline Cadillac Owners Member
    Jun 2016
    Florida
    47
    Hey I followed your advice and it still didn't fix the problems now. What can I do??
    globuslive's Avatar
    globuslive is offline Cadillac Owners Fanatic
    Automobile(s): Catera 2000 & Catera 2001
    Feb 2011
    US
    169
    If your speedo stops working and you get abs and traction lights on, its abs module, if lights are off, it might be simply bad contacts on IP cluster. Abs module won't affect tacho, since tacho signal doesnt come from that module. And trany speed sensor is nothing to do with speedo. Try to tap on cluster while driving, if it changes anything. Good luck.
  12. Remove Advertisements
