Is this bad? (Oil In Overflow)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Cadillac Catera and Cimarron Forum Discussion, Is this bad? (Oil In Overflow) in Past Cadillac Vehicle Discussion; I pulled up to work and heard bubbling from the overflow. opened the hood and theres oil coming out. After ...
    catera00's Avatar
    catera00 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Feb 2007
    Tucson, Az
    40
    390
    I pulled up to work and heard bubbling from the overflow. opened the hood and theres oil coming out. After the car cooled off I removed the cap and theres a bunch of thick sludge in there. No coolant. Theres no coolant or foam or cream on the dipstick or oil filler cap so I wonder if its related to that breather thing thats behind the motor. Every time I remove the intake, theres oil in it. Ideas? Thanks guys. Just hoping it will get me home after I put coolant in it.
    I just read this in a post here:
    >>The cam cover gaskets can leak and drip oil on the exhaust heatshields and create smoke. This is too expensive to leave to Cadillac. Order the gaskets and have a trusted local garage do the work or DIY. Cleaning the crankcase breather relieves the pressure that blows the oil past the gaskets.<< http://www.cadillacforums.com/forums...ac-catera.html
    I recently (3 weeks ago) changed my valve cover gaskets due to severe oil leaks. I wonder if my crank case ventilation system is cloged. It looked pretty funky but I didnt try cleaning it at the time. It looked like this one: Anybody ever have this happen? Is this a symptom possibly of a crank case breather clog? http://www.omegaowners.com/forum/ind...?topic=90653.0
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Is this bad? (Oil In Overflow)
    all that stuff has nothing to do with the cooling system
    either the oil cooler has busted or your headgasket is busted
    i would not drive the car
    you could render the engine un-repairable
    catera00's Avatar
    Feb 2007
    Tucson, Az
    40
    390
    Damn. Why is it sludge and not just coolant and oil? Thanks for the reply
  5. #4
    Sep 2007
    Wilmington, NC
    13,986
    coolant and oil looks like sludge ... kind of chocolate milky ... plus you may have had some sort of stop leak put in there at some point causing the chunks
  6. #5
    catera00's Avatar
    Feb 2007
    Tucson, Az
    40
    390
    You're 100% correct there. I did have stop leak in there. If I'm lucky and it ends up being the oil cooler. Is there any way to bypass that bastard ?
  7. #6
    Sep 2007
    Wilmington, NC
    13,986
    not that i know of ... we've done many repairs on the 3.0L for this (and similar problems)
    mostly for saturns ... the cateras don't seem to have this problem as much
    or maybe there's more of the saturns out there on the roads than cateras
    i wish i could be more help but i'm just a parts guy that knows enough about the service side of the business to be dangerous
  8. #7
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    Oil Cooler for sure
  9. #8
    catera00's Avatar
    Feb 2007
    Tucson, Az
    40
    390
    well I appreciate the help. Ive hd the cooler out before when I was chasing down a coolant leak and it looked like the newer style that replaced the oem ones. I believe the newer ones have thicker fins. Anyway, I'll tear into it and see what I can figure out. Anyone know if it will have any definite signs that its gone bad when I take it out? Maybe I can run some water through it and see if it leaks. Dont wanna buy a new one only to find out it was the Head gasket after all. Also, Will a coolant flush be enough to get all this oil and sludge out of my cooling system after I replace the cooler?
  10. #9
    Sep 2011
    Plainfield ILL
    59
    139
    Yes but you have to flush the heater core also other people on here are going to rip you an ass if you do it yourself if you cant recover the fluids good luck
  11. #10
    Sep 2007
    Wilmington, NC
    13,986
    radiator too... the whole coolant system is a horrifying mess now
    i'm thinking headgaskets more likely than oil cooler since that will overheat and/or over-pressurize the system causing the brown puke in your first post
  12. #11
    Sep 2011
    Plainfield ILL
    59
    139
    I think cooler pull the intake you'll see
  13. #12
    catera00's Avatar
    Feb 2007
    Tucson, Az
    40
    390
    I'll pull the oil cooler out first since its I'll have to take the intake off either way. If Im lucky and its the oil cooler, after I swap it, can it be driven to a shop for a flush or will it need to be towed? Should be ok to just fill it with water and drive it somewhere close by right? I wouldnt think about blastin that shit down my driveway into the earth. Dont worry about that.
  14. #13
    Sep 2011
    Plainfield ILL
    59
    139
    Yes fill it and drive it i myself would flush it from the earth it came to the earth it goes
  15. #14
    Sep 2007
    Wilmington, NC
    13,986
    Huh?
  16. #15
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Translation:
    Quote Originally Posted by hemic05
    Yes, fill it and it can be driven to a shop for a flush.
    He would personally just flush it himself.
    From the earth it came, to the earth it goes. ---
    The hell with the environment, so what if a bit of oil and coolant get on the ground.
  17. Remove Advertisements
