Is this bad? (Oil In Overflow) - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Cadillac Catera and Cimarron Forum Discussion, Is this bad? (Oil In Overflow) in Past Cadillac Vehicle Discussion; I have a garage set up for automotive repairs so yes i would flush it...
  1. #16
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    Re: Is this bad? (Oil In Overflow)
  2. #17
    catera00's Avatar
    catera00 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Feb 2007
    Tucson, Az
    40
    390
    So I did a test I saw done on youtube where you remove the coolant tank cap and run the car til it gets to operating temp. Once the thermostat opens, if the head gasket is blown, they say it will cause the crankcase pressure to go into the cooling system causing it to bubble out as if it was over heating. (See video) I did this and had those results. The coolant overflowed and bubbled like crazy even though it wasnt hot enough to be overheating. I am moving in a couple weeks so I havent torn the car apart yet to check the oil cooler. But Im thinkin head gasket.
  3. #18
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    If you remove the cap you will boil the coolant at operating temp.
    Do a bit more research here about northstar head gaskets.
  5. #19
    catera00's Avatar
    Feb 2007
    Tucson, Az
    40
    390
    will do. Thanks.
  6. #20
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,025
    any updates on this issue? Did you get it fixed?
  7. Remove Advertisements
