Results 1 to 5 of 5
Thread: 00-01 front door panel remove
    Feb 2012
    45
    hi need the 00-01 front door panel remove to put in a new door hinge/link how do I do that?
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Re: 00-01 front door panel remove
    Carefully so you don't set off the side impact airbags. Is the the door check that broke at the weld?
    Feb 2012
    45
    Oh yeah. This is the: 90564478, the link/hinge that goes between the door and front fender, not at weld.
    I also see the 97-99 is different from 00-01 the door panel is not the same.
    So instruction to remove the driver side door panel for 00-01? and how to install this link/hinge.
  5. #4
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    There are phillips screws around the bottom of the door panel down in the handel area then lift up on the panel on an angle it poooooof it will be in your hands jack
  6. #5
    Jul 2008
    712
    I took it to a body shop to fix. Someone I know. $250. This issue just goes to show how crappy this car really is. I driven over a million miles in my lifetime on many different cars, and I have never, ever experienced a car door hinge problem except for a squeak!
  • You may not post replies
