K134 Multifunction Module
Results 1 to 9 of 9
Cadillac Catera and Cimarron Forum Discussion, K134 Multifunction Module in Past Cadillac Vehicle Discussion; Hi, Does anybody have the Part # for the K134 Module for a 1997 Catera, and where to order it? ...
    fasttruck9 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2007
    14
    Hi,
    Does anybody have the Part # for the K134 Module for a 1997 Catera, and where to order it? I have the number for a 2000 but I'm not sure if it is the same. The 2000 is 90 494 163. Thanks.
    Thanks again,
    Wayne
    ThatCoolDude is offline Cadillac Owners Fanatic
    Automobile(s): Catera Sport
    Feb 2011
    28
    115
    Re: K134 Multifunction Module
    I fixed mine with a heat gun, its the same concept when doing it on a computer. You heat up the chip slowly making sure you don't stay on the same spot too long(the solder should remelt), or you can always try soldering the messed up spots. Your already thinking its worthless so try it out, you never know it might work out for you too.
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    Its the same part on all years. I belive you can go to gmpartsdirect.com and find for around $66
    Apr 2007
    14
    Thanks for the replies, for $66 I'll buy it new!!!
    Thanks again,
    Wayne
    io13 is offline Cadillac Owners Member
    Nov 2012
    1
    Hi all,
    Do not waste any money changing it. Unplug the module (see other threads for the process) open the gray box and take the chip out, you need to cut or somehow weaken the upper part of the clip that hold the chip to the gray box. Once the chip is out redo all the solders, spray wd40 and youre good to go.
    My radio was going on and off and i just sprayed wd40, it worked for a month. Then the trunk, fuel door and radio started to have issues and wd 40 would not solve the problem this time. So the solders are the problem with that box.
    Hope that helps
    liweih21 is offline Cadillac Owners Member
    Feb 2012
    45
    is buying the k134 enough or does it have to be reprogrammed?
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    nooooo. this is just relay.....
    gvjv3 is offline Awaiting Email Confirmation
    Automobile(s): 97 forest Green catera
    May 2012
    119
    you can either repair the K134, which has 4 or 5 relays in it, or replace it with a new one, I repair mine, look on the bottom side and check all soldering points and found about 5 spots where the solder was crack, resolder them and them put back in car, although I didn't clip it back where it was, I just let it hang, I believe the closing of the door many times over time cause the vibration that cause the points to crack, now everything works for me
    Doctur J is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac Catera
    Mar 2011
    7
    That is the correct number per GM. Try going to a auto salvage yard and get one. I paid $6.00 for mine
  12. Remove Advertisements
