1998 catera smells hot. 50k miles
Results 1 to 9 of 9
Cadillac Catera and Cimarron Forum Discussion, 1998 catera smells hot. 50k miles in Past Cadillac Vehicle Discussion; hello, I have a 98 catera, 50k miles. The car was working fine until i washed the car in the ...
    hillz is offline Cadillac Owners Member
    Automobile(s): 98 catera
    Mar 2012
    35
    4
    Question1998 catera smells hot. 50k miles
    hello,
    I have a 98 catera, 50k miles. The car was working fine until i washed the car in the drive way, he did nothing special but just wash is and soap it down. To let the car dry i took it out on the highway it was a very nice day. well the car started to over heat and the temp went all the way to max and the light came on. I pulled over and let it cool down, started it up again and it did the same thing so i turned on the air like the manual said to pull air through the radiator. ( this car was owned by my mom previously and it had everything done to it and was taken care of and all fluids are fine) . So i get the car home, let it sit then drive it again after a few hours well the service engine soon light came on and so i took it to autozone and they checked it. They said it was running at high rpms but that it was a little on the hot side ( i could of told them that). So now it runs with the temp 3/4 near top of gauge and i smell a hot smell when the car sits and runs for a while, the fans do kick on but i get that hot smell . Does anyone know what could be wrong? i will attach a pic of the temp gauge taken few days ago.
    http://img545.imageshack.us/img545/6017/img2082oy.jpg
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    Re: 1998 catera smells hot. 50k miles
    Change the thermostat
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Is the radiator/overflow tank full?
    If not, could be a water pump leak or heater control valve that is bad
    Mar 2012
    35
    4
    Quote Originally Posted by kaustein View Post
    all the fluids are topped off, no leaks at all. I will look into the heater control valve , thermostat. thanks for the input guys.
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Did you spray under the hood? If so it could be one of the fan fuses blew. Same for the aux water pumps. The gauge at 3/4 is high but not dangerous. Red zone is. Your heads should be safe but get this fixed before summer temps come around.
    Mar 2012
    35
    4
    i checked both fused boxes, under the hood and under the steering wheel and no fuses were blown. The fans do kick on when the temp gauge is at the temp in the picture. I didnt spray under the hood, just wheel wells and thats it.
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    I dont think the wash has a thing to do with problem... coolant is not flowing prperly... the fans are turning on, so the sensors are all working proper.
    is coolant clean? thermostat sounds logical... there are 2 waterpumps... and the control valve as mentioned.. possibly plugged shoot whats that thing int he firewall area.. its like a mini radiator.. I can not think of the name... .
    I would say coolant is not flowing properly.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    in my situation it was aux water pump (one that close to overflow tank) burn out, i replaced with another one from junk yard works grate now.
    but i got in more problem cuz that burning pump over heat and creaked my radiator so had to replace my radiator too(((
    Jul 2008
    712
    At 50k the repairs start! Suggestion. Once you get it fixed, get rid of it.
  12. Remove Advertisements
