2001 Sport "S" flashing on panel & all gear modes (P, R, D, 3, 2, 1) light up
Results 1 to 12 of 12
Cadillac Catera and Cimarron Forum Discussion, 2001 Sport "S" flashing on panel & all gear modes (P, R, D, 3, 2, 1) light up in Past Cadillac Vehicle Discussion; I've read through the previous posts on this topic back from August 2011, but there does not seem to be ...
    ondale is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera Sport
    Mar 2004
    Chicago
    147
    I've read through the previous posts on this topic back from August 2011, but there does not seem to be 1 viable solution. So let's re-ask the question, since I just recently have experienced this. Reverse is all good. When I place it in "D", the gear modes sometimes all like up. I may drive for awhile, then I get the flashing "S" and then it doesn't want to start in 1st gear from a dead stop and the Check Engine Light comes on. The next day, the CEL is off, and I select "3" by touch, instead of "D" and no problems with city driving. Highway driving is another story, it won't kick over to 4th gear, so the RPMs get up in the low 3000's. For the past day, the CEL hasn't come back, but I still get the flashing "S" if I try to drive the car in the "D" selection, plus all the gear lights light up, and move around. Strange.
    I've read that it could be a harness, a neutral safety switch, MAF, reset the car by pulllin the battery cable, etc. One just said, replace the transmission. The transmission works fine when the "D" stays lit, but once the light arbitarily moves from that while driving, I get the flashing "S". It seems like some kind of switch failure., it's But no one has offered up a solid answer.
    Any ideas? Where is CateraMV6 when you need him? Thank
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    Re: 2001 Sport "S" flashing on panel & all gear modes (P, R, D, 3, 2, 1) light up
    whats the code i'll look itr up for you
    MyOpel's Avatar
    MyOpel is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera Y57XE
    Oct 2005
    Toronto
    203
    shift position switch. its on the side of the trans
    TitanCTS's Avatar
    TitanCTS is offline Cadillac Owners Fanatic
    Aug 2003
    Watertown, MA
    32
    199
    Neutral Safety Switch. Common problem. Replace it!
    Mar 2004
    Chicago
    147
    What is a shift position switch, first time I heard that.
    MyOpel's Avatar
    Oct 2005
    Toronto
    203
    Quote Originally Posted by ondale View Post
    its what tells the computer what gear you put it in
    Mar 2004
    Chicago
    147
    In your photo, isn't that the Neutral Safety Switchstandard_neutral_safety_switch_ns322_cadillac_catera_01_97_b.jpg
    AHazzardToAll's Avatar
    AHazzardToAll is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Catera Sport
    Jun 2007
    Mooresville, IN
    26
    677
    Yeah, same thing.
    cheady55 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2008
    37
    1
    did this fix the problem, i have the same problem too
    Mar 2004
    Chicago
    147
    Yes it did. Bought the part from Amazon.com ACDelco E2297 Switch Assembly
    http://www.amazon.com/gp/product/B00...00_i00_details
    Kwolfel is offline Cadillac Owners Member
    Automobile(s): 2000 catera
    Sep 2011
    61
    1
    In my situation the car will not start. I get the blinking S sport light and so far the shifting and indicator lights are all normal. Any thoughts about if this switch would allow the starter to work but for some reason not allow the car to start???
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The starter is disabled in all gears but Park and Neutral.
    Pull your codes.
  15. Remove Advertisements
