Catera heater control valve
Results 1 to 13 of 13
Cadillac Catera and Cimarron Forum Discussion, Catera heater control valve in Past Cadillac Vehicle Discussion; Can someone please post where to get that heater control bypass valve...
    hemic05 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS 1SG 2001 Cadillac Catera Sport
    Sep 2011
    Plainfield ILL
    59
    139
    investor74 is offline Cadillac Owners Enthusiast
    Automobile(s): '97 Forest Green Catera
    Nov 2005
    674
    Re: Catera heater control valve
    Sep 2011
    Plainfield ILL
    59
    139
    Not those the generic one withoput the vacum port someone had a picture of it on this website and where to get it
    kaustein is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Jul 2008
    712
    Quote Originally Posted by hemic05 View Post
    Just go to the dealer to make sure you get the right part.
    Mine cost me <$150 part and install Stopped the quart a day leak
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    62
    1,840
    Rockauto.com
    Sep 2011
    Plainfield ILL
    59
    139
    I lost all heat replaced the control valve to stop a leak i wonder if the secondary water pump can be a problem it seems i dont have any circulation to the heater core
    PrimeTimeElite's Avatar
    PrimeTimeElite is offline Cadillac Owners Member
    Automobile(s): Catera 1999
    Dec 2005
    Colorado
    39
    http://www.gmpartsgiant.com/parts/gm...-90566947.html
    $66, a lot better than some online places and the dealer. I've used this place before, it's all genuine GM/ACDelco stuff.
    catera00's Avatar
    catera00 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Feb 2007
    Tucson, Az
    40
    390
    Do what I did and bypass it all together. I changed mine 3 times and finally just replaced it with a T connector and havent had a problem since. So for $5 my heater bypass problem is permanently resolved. I did it back in may so for 7 months its been working fine.
    From my post about it:
    I just plugged the vacuum line. So far its working fine. No leaks and the temp is staying cool. The car heated up operating temp as fast as it normally does. So for $5 its a quick cheap fix. Took me about 30 min from start to finish and most of that time is spent removing/installing the intake and what not. The heater works as well.
    catera00's Avatar
    Feb 2007
    Tucson, Az
    40
    390
    mine did the exact same thing and a coolant flush fixed it. I actually had it in the dealership to replace the heater core and they tried a flush first to save me some $$. Thank goodness cause it saved me about $1200. If the car isnt overheating and the only problem is no heat, I highly recommend a coolant flush. Any mechanic can do it and its cheap. Something is probably just clogged somewhere in the system.
    I made a video of how to test the Aux. Water pump. This was the one on the passenger side of the car. I just un-bolted it and removed the hoses.
    Sep 2011
    Plainfield ILL
    59
    139
    On the heater control valve does the lower heater core hose go to the top or bottom of the heater control valve???
    Tdalelewis is offline Cadillac Owners Member
    Jun 2012
    29
    1
    Quote Originally Posted by catera00 View Post
    I just did this today and it worked. 5 dollar fix. Took my check engine light away and everything!!
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Mar 2012
    Wilmington, NC
    429
    i replace twice already got from junk yard. third time i went to ebay got new for like $20 and work for me 2 weeks. i will try that t connector and see how its work.
    but guys there is some kind a problem that this valve cant hold either hot or pressure!!!!!!!!!!!!
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    ok does any body know what heater control valve for.
    heater control valve - bypassing coolant for circulation in cooling system until its open. when valve open, hot coolant travels trough heat radiator that locate inside cabin (its used to heat cabin when u on heating mode, usually in winter) that valve controlled by air suction to open and close (it's that air hose u see on the top of the valve) u can plug one of the hose that going to radiator and just use line connector "---" extend of " T " connector but u will lose heat ability in winter when u will try to heat your car in cold days, when " T " connector in use coolant will constantly travel through heat radiator, with out fans turn "on" in while you will damage radiator and coolant will start leak in cabin, also when that " T " connector installed cold air (when u use A/C) will travel trough heat radiator that HOT!!! and cold air will gonna be cold enough!!!!!!. when your A/C or heat or just fan mode "off" u will feel hot air coming from A/C vents !!!!!!
    so ask your self do u really need that T connector!!!!!
  16. Remove Advertisements
