Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: A/C & Heat
Old 10-25-04, 02:46 PM
ennbee ennbee is offline
View ennbee's Photo Album
Casino Cash: $250
No A/C or Heat
New Member!!!
I have a 97 Catera With no heat or A/C.
Can anyone relate to my problem?
  #2 (permalink)
Old 10-25-04, 07:27 PM
Vesicant's Avatar
Vesicant Vesicant is offline
It takes the caek.
Cadillac(s): 0
View Vesicant's Photo Album
Casino Cash: $6565
Re: A/C & Heat
First off, does the climate control center "light up" ?
Does the blowerfan work? (if the climate control works)
... need more info.
  #3 (permalink)
Old 10-26-04, 09:58 AM
mastertech mastertech is offline
View mastertech's Photo Album
Casino Cash: $250
Re: No A/C or Heat
Try cycling your hazard fuse if your control head does not seem to be working....common problem!
  #4 (permalink)
Old 11-06-04, 03:25 PM
Casino Cash: $250
Re: A/C & Heat
Thanks for responding!
I've been tied up changing my valve cover gaskets.
JefferyG, the Climate control console lights up and all the functions work but the blower is'nt curculating the heat or air. doe's this info help in determining what may be the problem?
Mastertech, I have my battery disconnected right so I can't cycle the hazard fuse
  #5 (permalink)
Old 11-07-04, 12:15 AM
Vesicant's Avatar
It takes the caek.
Cadillac(s): 0
Casino Cash: $6565
Re: A/C & Heat
So if im correct on this, your a/c controls work and so does your blowerfan. But no flow is comming out of the vents? First try mastertechs probable solution..
Then;
1. It could be clogged - the piping/various parts related. May require mechanic to go through system.
2. The climate control unit is not controlling it. Meaning its bad.
3. There are 5 stepper motors, making changes in the system for various things like flow direction. One of these systems may not be working, or closed shut.
A thing to try (with the key in the on position) is hold the auto and off buttons on the climate control for 5+ seconds. This should attempt to move the valves to their home position. You may beable to hear them moving, and if theres no noise then somethings not working or its fine... and theres another problem yet to be discovered.
  #6 (permalink)
Old 11-07-04, 10:46 PM
Casino Cash: $250
Re: A/C & Heat
The controls are working fine but the blower fan does not work, all fuses are intact and relays appear to be in working order, is there a way I can test the blower fan?
  #7 (permalink)
Old 11-08-04, 03:57 PM
Vesicant's Avatar
It takes the caek.
Cadillac(s): 0
Casino Cash: $6565
Re: A/C & Heat
Take out the fan, and test the connection for power. If theres power going to it but the fans not working then its the fan.
  #8 (permalink)
Old 11-30-04, 11:25 PM
AllenPacla AllenPacla is offline
View AllenPacla's Photo Album
Casino Cash: $545
Re: A/C & Heat
Is there an easy way to take out the fan, perhaps some instructions on how to do it. Thanks
  #9 (permalink)
Old 12-03-04, 08:08 AM
vogel81 vogel81 is offline
View vogel81's Photo Album
Casino Cash: $250
Re: A/C & Heat
I'm not sure about the Catera, but many of the blower fans have a fuse located on them along with a fuse in the fuse panel. I would check the fuse on the blower before replacing the blower.
Tags:
a or c, heat
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
