Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac Catera and Cimarron Forum
Cadillac Catera and Cimarron Forum Forum for discussions regarding the Catera and Cimarron.
Cadillac Forums: !!!***help***!!!
Old 10-22-04, 07:56 PM
y2mjm y2mjm is offline
View y2mjm's Photo Album
Casino Cash: $250
!!!***help***!!!
I recently returned from a long trip(about 1000 miles) and
while pulling into my driveway, I heard what sounded like a flapping
sound. As I hushed my kids to try to listen I noticed that the
sound did was faster as i accellerated. Somewhat like a tapping or flapping sound. While pulling into my
parking spot, the car stalled, and will no longer start. Lights and accessries work(although i think they are now starting to die after a few days of trying to diagnose this problem). It sounds like a high pitched, geary, whining sound with some thudish whipping (which goes away after about a second....then it remains a steady sound as i described above)as i try to start.
To me it seems like the starter isn't working, but i dont know a thing about cars. Just how to follow directions & turn wrenches. Then driving them is pretty fun too when they work. First thought was that a belt was
snapped or something. I havent noticed any broken belts upon
inspection or anything out of the ordinary. Please help.
  #2 (permalink)
Old 10-22-04, 08:04 PM
Casino Cash: $250
Re: !!!***help***!!!
also, on my trip i did notice the radiator light came on once or twice when the engine was cold. The fluid level is good. It stayed on for a minute or so and went off when the car got warm.
  #3 (permalink)
Old 10-22-04, 08:37 PM
Vesicant's Avatar
Vesicant Vesicant is offline
It takes the caek.
Cadillac(s): 0
View Vesicant's Photo Album
Casino Cash: $6615
Does the car run still?
When does it make the noise? Is the car low on power, does it seem like its missing?
  #4 (permalink)
Old 10-22-04, 08:56 PM
Casino Cash: $250
definately isn't running... made the first tapping noises as i was driving...tapping went away when i quit accellerating. i coasted into my parking spot and as i was coasting, cater stalled. Gets power but noticed tonight that lights did go out as i tried to start. While trying to start is when i get that whiny vreeerm noise...like the starter is firing(mabey) but wont crank.
  #5 (permalink)
Old 10-22-04, 10:49 PM
Vesicant's Avatar
It takes the caek.
Cadillac(s): 0
Casino Cash: $6615
Check the tension of the belt (push on the belt and see if theres tension)
Otherwise, it sounds like it may have done some damage internally... if not that then your starter may be damaged.
As for the engine, it could be some valves dropped out of their seats or one of them hit the piston. Somehow could be due to the cam tensioner issue on early Cateras. The tensioner would fail (or the water pump), causing the car to go out of proper cam timing when running and then bend the valves, hurt pistons and etc.
Otherwise, dont drive it or attempt to start it anymore and get it to a mechanic to check out the engine until you know whats gone bad.
Btw, what year is your Catera?
  #6 (permalink)
Old 10-22-04, 11:05 PM
Casino Cash: $250
The belt feels as though it is properly on. i am able to press it down approx 1/2 inch. It is the one directly to the front of the engine right? mine is the '97 model.
  #7 (permalink)
Old 10-22-04, 11:22 PM
Vesicant's Avatar
It takes the caek.
Cadillac(s): 0
Casino Cash: $6615
From what i read and know , even if the tensions good, the belt can slip and your timing goes. From either the tensioner slowly dying, or the belt being old. It could also be your waterpump has injested its bearings and the engine sucked them in. Id start with checking the starter first before anything else.
Your best option right now is to get it to a mechanic or a cadillac dealer to have them find what the problem is. If its not the starter, a siezed engine or an internally damaged one is what you have right now.
To add... see if you can have a friend look while you start the engine, to see if its turning over while you attempt to start it. Do not try this more than once being that its in an unknown state.
  #8 (permalink)
Old 10-22-04, 11:28 PM
Casino Cash: $250
would a carfax report be a good idea to see exactly what recalls have been performed on my vehicle? i.e, cam tensioner?
  #9 (permalink)
Old 10-22-04, 11:41 PM
Vesicant's Avatar
It takes the caek.
Cadillac(s): 0
Casino Cash: $6615
Your Cadillac dealer can look it up (if the recall was done by a Cadillac dealer in the first place)
  #10 (permalink)
Old 10-22-04, 11:42 PM
Casino Cash: $250
worst case, how much$$$ do you think i should end up paying to get it fixed?
Tags:
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
