transmission lights! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Cadillac Catera and Cimarron Forum Discussion, transmission lights! in Past Cadillac Vehicle Discussion; I'm taking it back to the shop this morning. I'm thinking it may be the MAF sensor. I was just ...
  1. #16
    Rodney6661 is offline Cadillac Owners Member
    Automobile(s): 1983 Cadillac Deville
    Jun 2011
    Birmingham,AL
    26
    Re: transmission lights!
    I'm taking it back to the shop this morning. I'm thinking it may be the MAF sensor. I was just looking at problems you have when the MAF is going bad. But i'll let you know for sure.
  2. #17
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Did you ever check for trouble codes? If the CEL is on, a code has been set.
  3. #18
    Jun 2011
    Birmingham,AL
    26
    I had to get a Acdelco MAF sensor. The reman was no good. So far everything is fine.
  5. #19
    SoapMart's Avatar
    SoapMart is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Catera
    Apr 2011
    Aubrey. TX.
    73
    I have replace tcm bcm ecm and nss. And some other items. My S is still flashing. My check engine is still on.
    Any input?
    As for the reset mode a Cadillac dealership just told me it was to drive it more than 60 mph on the highway for 3 miles.
    Park it. Do it again the next day and it should reset. So I drove it 50. 2 days in a row. Did nothing. Is it reset? I have no idea. How can I tell?
    S and check engine still on!
  6. #20
    SoapMart's Avatar
    Apr 2011
    Aubrey. TX.
    73
    showing ocdes p1700 and p0705 still.
  7. #21
    Sep 2010
    East Boston MA.
    29
    26,325
    P0705 - Trans Range Switch Circuit- This is your problem.
    P1700 - Transmission Control Module (TCM) Requested MIL Illumination- I believe this just means the TCM set the S light/CEL
    Quote Originally Posted by SoapMart View Post
    That sounds like a "drive cycle". The car must go through a set number of drive cycles after PCM memory is lost (battery disconnected, codes reset) before it will allowed to pass state inspection.
    Any time the CEL is illuminated, a DTC (Diagnostic Trouble Code has been set, the car will tell you what is wrong with it (or at least give you an idea of where to start looking for problems). Throwing parts at a problem is never a good way to go.
  8. Remove Advertisements
