Transmission help
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Cadillac Catera and Cimarron Forum Discussion, Transmission help in Past Cadillac Vehicle Discussion; I know the transmisson in my catera is a sealed unit. But i was wondering is there a way to ...
    98CadiCatera is offline Cadillac Owners Member
    Automobile(s): 1998 Cadillac Catera
    Jul 2011
    28
    Transmission help
    I know the transmisson in my catera is a sealed unit. But i was wondering is there a way to add trans fluid to the car. The problem im having is the car shifted fine yesterday
    but today it wouldnt shift past first. oes anyone have any thoughts on this. i really hope its just low on fluid.
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    Re: Transmission help
    my 00 catera has a side fill, car has to be up in the air and there is a port on the side.. u fill it untill fluid spills out. its on the passenger side. Im not sure if a 98 is the same, but may be. car has to be leval befor replaceing the fill cap to be sure your at the right level .
    Jul 2011
    28
    Thanks for the information
    waco-brian's Avatar
    waco-brian is offline Cadillac Owners Fanatic
    Automobile(s): Catera 98 & 99
    Apr 2010
    Waco,Texas
    50
    113
    the 98 has a fill on the side also, it is how you fill and check the fluid but the car must be warm and running when you do this
    cra889 is offline Cadillac Owners Member
    Automobile(s): 1999 Catera
    Feb 2014
    Near DC
    24
    99 catera sport / trans fliud what type, what Grade... Just want to be prepared!!!???😎
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,024
    I believe its Dexron III or maybe even VI, just check the bottle at your local parts store.
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Dexron 3 its original fluid, dexron 6 its new synthetic that should help with shift and extend life. I replaced my oil with DEX 6, twice!!!, ot took 5 quarter each time. Also I used Castrol brand - not cheep!
    New filter was put in too after second change.
    Just to add oil:
    Make sure u do it on hot transmission, its mean u have to drive car for at lease 15 miles none stop not just let it seat running until it heats up!, when u rased your vehicle its need to be leveled, i used 6 jack stand all around. When u adding oil, engine need to be running, just unscrew plug/bolt on bigger pan that located on passenger side and add keep adding oil untill it starts to come out, then quickly screw and tight bolt/plug back. Now u can turn vehicle off.
    To add oil u have to use hand pump, I bought mine at Harbor Freight fo $10
    pinto is offline Cadillac Owners Member
    Automobile(s): 1997 cadillac catera
    Feb 2014
    44
    13
    i have a 97 Cadillac Catera and when taking off from a stop if i dont push the gas easy it will slip.plus when it is cold it will stay in first gear for about 50-100 feet of taking off from a stop just bought it and know nothing about this car i even checked auto zone for a Haynes manual but they said they dont make one.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    We're up to DEXRON VI guys, not IV.
    Pinto, Haynes manuals are nearly worthless. If you really want a manual, get a " realL Helm FSM. Start by checking the transmission fluid level.
    kaustein is offline Cadillac Owners Enthusiast
    Jul 2008
    712
    Quote Originally Posted by pinto View Post
    When cold, shifts were slower and at higher rpms. I'd drive it cautiously until the car gets to operating temp. Also read the posts here as the car has many, many issues.
    Feb 2014
    44
    13
    thank you for the help but i have one more question i dont know if this is the right place to ask but Sunday we was driving from PA to IL and about half way back i notice that it was shaking really bad like a bad tire well i got out to check and it is wearing the rear tires really bad on the inside and about 10 miles down the road the driver side rear tire blew out it looks like both rear tires lean in a lot at the top.
    Sep 2010
    East Boston MA.
    29
    26,323
    Pinto, if the wheels are tilted inwards at the top, you either have very worn suspension components, or your ELC system is inop and your rear springs are sagging or broken.
    JohnJJO's Avatar
    Mar 2012
    Wilmington, NC
    429
    Quote Originally Posted by kaustein View Post
    Never solved my cold shift issue, transmission flush and oil changed to DEX 6 didnt helped. Its still wouldn't switch to second gear in first 100 feet
  16. #14
    Jul 2008
    712
    Front suspension is a problem area. And the rear springs break close to the tray they sit in.
  17. #15
    Feb 2014
    44
    13
    what about the 97 where do i check and fill the tranny
  18. Remove Advertisements
