Transmission help - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Cadillac Catera and Cimarron Forum Discussion, Transmission help in Past Cadillac Vehicle Discussion; Cra889SportCatera Transmission???help I hate not knowing, transmission on the Catera is an Enclosed port on the tranny itself... Just finding ...
  1. #16
    cra889 is offline Cadillac Owners Member
    Automobile(s): 1999 Catera
    Feb 2014
    Near DC
    24
    Cra889SportCatera
    Transmission???help
    I hate not knowing, transmission on the Catera is an Enclosed port on the tranny itself... Just finding that the it's best to fill tranny while hot, using a hand pump... Fill till there's a slight overflow... Definitely use dextrin 6, Castro
    Quote Originally Posted by pinto
    what about the 97 where do i check and fill the tranny
    cra889SportCatera99
    Dang Catera, on the tranny it's self... Definitely get linkage check or adjusted... Owner manual is For real... Meaning small adjustment, reprogramming stuff will save you a lot of Pain... I had my engine flushed... Tranny rebuilt and she leaks, another issue... Hope it helps... Got it all from the Moist Cabbage, Submariner Dude!!! Welcome to the Village
  2. #17
    elvin315's Avatar
    Jan 2007
    Warwick, NY
    63
    1,840
    Re: Transmission help
    In their infinite wisdom GM decided that owners shouldn't check the transmission fluid themselves and deleted the dip stick/filler tube. The way to check it now is to crawl underneath and undo the pan's plug. Reach in with your finger and feel if the fluid level is even with the bottom of the plug opening. The car must be warm, not hot, and on a level surface. Smart move, huh?
  3. #18
    JohnJJO's Avatar
    JohnJJO is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Catera Sport
    Mar 2012
    Wilmington, NC
    429
    Quote Originally Posted by elvin315 View Post
    Dude. Car have to be running at this time, other wise as soon as u open that plug oil start to leak like crazy. Transmission need to be hot too while u checking, my services manual saying that! And u have to take it on the road for minimum 15 miles before start to checking! So tranny could reach it normal temp!!!!!
  5. #19
    retho78 is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Sep 2007
    1,025
    Use Dexron 4 and not 6
    Thanks.
  6. #20
    Buster28 is offline Cadillac Owners Member
    Automobile(s): 2000 ETC 18K miles, 1991 Allante 11K miles, 1996 ETC (sold)
    Sep 2010
    RI
    23
    There never was a Dexron IV (4) or V (5) ATF. The product went from III H to VI (6), Dexron VI is a synthetic, Dexron III H has been discontinued but Castrol and others make an acceptable substitute. I use Castrol Transmax Import Multi-vehicle which is a Dexron III substitute and it performs satisfactorily.
  7. #21
    Feb 2014
    Near DC
    24
    Cra889CateraSport99
    I've found out from Wisdom Guru y'all... That Dextran 6... Friggin level hot Trans Check... Passenger side, finger In the whole... Hand pump application... Up on the lift... HHHMMM... What if you got a leak small???
  8. Remove Advertisements
