| Re: wheel is stuck to car Spray tons of WD-40 into the bolt holes and if you can. Grab the wheel on the left and right and tug on either side (Back and forth, like a rocking motion) just enough so that it moves but not like your trying to rip it off otherwise you would bend the lugs.
If that doesnt work after repeated tries... then it will take some cutting of the wheel, or even heating up of the wheel center with a torch. Both of which arent good.
Sorry, I had problems with brakes on a Ford once.. the rotor wouldnt come off and with a sawzall had to cut chunks of the brake rotor off and go at it with an air chisel. |
