HELP!! 97 Catera Fuel Door and Radio Problems
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, HELP!! 97 Catera Fuel Door and Radio Problems in Past Cadillac Vehicle Discussion; I have a replaced the k-134A (part# 90449163) and fuel door still won't open and radio blinks when it wants ...
    JBB1961 is offline Cadillac Owners Member
    Automobile(s): 1997 Catera
    Feb 2011
    I have a replaced the k-134A (part# 90449163) and fuel door still won't open and radio blinks when it wants to.....my wife is about to run out of gas, plus I am on a time crunch.....will someone please help me??
    hgqguy's Avatar
    hgqguy is offline Cadillac Owners Fanatic
    Automobile(s): catera
    Nov 2009
    Rochester NY
    37
    449
    Re: HELP!! 97 Catera Fuel Door and Radio Problems
    look in the trunk, I belive there is a release for the fuel door in there on the passenger rear quarter panel.
    Feb 2011
    can't find the fuel release or else am not looking in the right place.....where else might it be
    hgqguy's Avatar
    Nov 2009
    Rochester NY
    37
    449
    honestly it sounds like a broken wire, or bad ground behind the dash area... cause it sounds like a short... did u check radio and gas door fuses?? the was the relay you replaced a new one?? did u check to see if battery might be dead in remote? um... Im not sure. Im almost sure there is a release in the trunk.. Mine is a newer model and differant. pull back the lining in the trunk.
    i cant really help further..
  7. Remove Advertisements
